Google reCAPTCHA V2 - New WB16 Form Object Selection - No Tab Index field and Validation?
Issues related to forms.
ColinM
Post by ColinM »
Hi Pablo,
Is there a reason why the updated WB16 form captcha object doesn't include a Tab Index field please? Can it be considered for future consideration?
Also, I have set Ajax validation on a Client's form and there is no error message adjacent to the field if I don't tick the captcha - a submit just goes straight to the failed page. Let me know if you need a project extract please Pablo.
Yours truly
Colin M
Western Australia
Re: Google reCAPTCHA V2 - New WB16 Form Object Selection - No Tab Index field and Validation?
You can set the tab-index via the 'Tab Index' properties.
At the moment this filed is hidden when you select Recaptcha, but you can make it visible by selecting 'Default'. After you have set the value you can switch back to Recaptcha.
There is no AJAX validation for captcha, but you can disable/enable the submit button using events.
Related topic:
https://www.wysiwygwebbuilder.com/forum ... =5&t=89516
ColinM
Post by ColinM »
Ah Ok - I guess having Ajax validation for the default captcha with the Validation tab still there when you change it to V2 got me confused.
Thanks Pablo - so in short - still no validation for Captcha V2 and need to use event on submit button.
Yours truly
Colin M
Western Australia
ReCaptcha v2 is third party functionality. It does not support validation.
However, it sends an event when the Captcha is solved. So that can be used to 'do something', like enabling a button.
ColinM
Post by ColinM »
OK - sounds good Pablo - thank you! 8)
Yours truly
Colin M
Western Australia
