[SOLVED] Icon Menu: Log Out?
AliGW
Post by AliGW »
I have an icon menu that has a link to the login page for my members' only area. In the members' only area, there is going to be a matching menu to navigate the secure area. Where on the main site's menu I have the Log In option, I'd like to have Log Out in the members' area. Is it possible to add the logout script to a menu button?
https://www.eastipswichcameraclub.co.uk/
Ali
Retired, but still loving to learn & very busy.
https://alisongwright.me.uk
Novice with WWB, but was an avid user of Serif WebPlus before.
Fairly expert at Microsoft Excel (but not VBA) & Affinity by Canva (for page layout).
Re: Icon Menu: Log Out?
What you can do is link a dedicated logout page, where you add this script at the start of the page.
<?php
session_start();
unset($_SESSION['username']);
unset($_SESSION['fullname']);
unset($_SESSION['role']);
AliGW
Post by AliGW »
So an empty page with just that code? And do I set that to divert immediately to the index page?
Ali
AliGW
Post by AliGW »
This works well, however the LoginInfo object still shows me as logged in. Is there something else that we need to do to reset that?
Thanks.
Ali
You can use the 'redirect' option in the page properties or use code like this:
<?php
session_start();
header('Location: ./index.html');
exit;
Once you are on a different page, the username value should no longer be valid.
AliGW
Post by AliGW »
Yes - as I said, I have that working.
What about the issue with the LoginInfo object still showing me as logged in?
I log out of the members' area and am taken back to the index page - works nicely.
Then I go back to the login page.
Expected: my logininfo object will not show because I am now logged out.
Observed: the logininfo object still shows, even though I am a logged out user.
Ali
It is still shows, then the session variables have not been reset.
AliGW
Post by AliGW »
I’ll try clearing cookies again and retest.
Ali
AliGW
Post by AliGW »
It is still happening, so session cookies are not being cleared. What can I do? It isn't actually logging me out at all.
Ali
Did you add the code at the very top of the page?
AliGW
Post by AliGW »
I converted the object to a form. The code is at the very top of the page, yes. I haven't done anything to it. There is no other PHP code on the page.
Do you want a temporary login so you can see the issue?
Ali
AliGW
Post by AliGW »
Just to say that the timeout logout (after ten minutes) logs the user out completely, so it's just the logout menu item that isn't working.
Ali
Do you mean that you have converted the logout button to a form?
That will not work with a link because the code expects to be called from a form.
The code I've shared is not the same.
AliGW
Post by AliGW »
No. I converted the login control to a form.
The logout is the menu item as you advised earlier in this thread - it links to a page containing the code you gave me earlier.
Am I supposed to put a logout button on the page linked to in the menu? If so, then that’s not really going to work for me.
Ali
The code from the logout button will not work in this case.
Instead, please use the code I have included in my initial reply.
AliGW
Post by AliGW »
That’s what I am using. I don’t know why you think that I am using code from a logout button.
I have linked the menu item to a page that contains your code in its header. I’ve tried the code with and without exit; added at the end.
The page redirects to the index page. I set this in page properties.
The code is not logging me out as I remain logged in.
So, what now?
Ali
So, that is why I thought you did not use my code.
Does the standard logout button work?
AliGW
Post by AliGW »
I’ll test some more tomorrow.
Thanks. 🙏
Ali
AliGW
Post by AliGW »
A regular logout button works correctly.
And a clear head this morning has made me realise what was wrong. The code needed to be:
<?php
session_start();
header('Location: ./index.php');
exit;
and the logout page needed a .php extension.
All is now working perfectly - thanks!!! :D
Ali
