cryptocoin template no images showing
ideasdesign
Post by ideasdesign »
i have upoaded the files on the preview its fine but when i upload to the server there is no images can anyone point me in the right direction ?
Re: cryptocoin template no images showing
Are you sure you have published all files?
What is the URL of the page?
ideasdesign
ideasdesign
I have pictures of horses as shown and i want to take the video off.
ideasdesign
Do i have to rename the page to index.html ?
Are you sure the image has been published?
It looks like the image is missing on the server:
http://private.epizy.com/images/horse-h ... rtrait.jpg
ideasdesign
i have replaced the one that was there and the new image will not upoad to the server the image is horse head close up portrait it doeant matter what image i use for the background it does not show
Maybe your website space is full?
or maybe the file name is not supported by your web host?
Are there any errors in the publish log?
ideasdesign
how do i find that out sorry new to this but thankyou pablo
ideasdesign
ideasdesign
welcome-carousel,Invalid event target: welcome-button1',The object has an event that refers to an object that is no longer on the page.
welcome-carousel,Invalid event target: welcome-button2',The object has an event that refers to an object that is no longer on the page.
welcome-carousel,Invalid event target: welcome-button3',The object has an event that refers to an object that is no longer on the page.
upStickyLayer,Object is outside the viewport,The object's outline is outside the page boundaries.
upIcon,Object is outside the viewport,The object's outline is outside the page boundaries.
headerHtml,Object is outside the viewport,The object's outline is outside the page boundaries.
firstStepsImage,Doubtful size,The size of the object is zero.
calcImage,Doubtful size,The size of the object is zero.
Did you republish the page?
The page is still using the old file.
ideasdesign
yes i have republished the page but stil no background image
It works for me now,. I can see the image.
Mayne you will need to clear your browser cache?
ideasdesign
ok thanks ill try that
