Extension Bulider 7.2
Re: Extension Bulider 7.2
Please do not curse!
I have the best intention to help you even through there is no support on custom extensions.
Do other features with rich edit work?
For example can you open the tooltip or blog properties?
If not, then there is a problem with richedit on your system.
Dragos
Post by Dragos »
Please try to see that...is about JUST Rich text .....tank you for your help and i try to tell you what problem i have...me and wwb
https://mega.nz/file/QFoUwZhS#hBCbW-yhx ... tWsiPIx5pw
In that movie show you with extension settings in both versions...
Yes..I can easily open the properties of the page you saw..and please believe me that I don't blame anyone, it's just that it's impossible for me to understand what you don't understand.
Use Win11/64bit, wwb20 . Have wamp64 server on windows 10/64bit with last mysql, php, phpmyadmin, mariadb....
Thanks for all!!
Your movies do not give me enough information, I need to know the exact configuration.
I have tried my own extensions using richedit and they all work in WWB 18.1.1.
So, there is either something wrong with your configuration or with the extension. Or a specific combination that makes it not work,.
The only way I can help you with this is if you share a demo.
Also, did you try it on another computer?
Dragos
Post by Dragos »
Here is page property :
https://mega.nz/file/cBolUJwb#CzZVNpGeD ... AMSZFdMQEU
Ok ..I'm probably an idiot who doesn't understand.. The same UNMODIFIED extension went on wwb17 with all its versions, the same UNMODIFIED extension and with the same configuration worked and works on all versions of wwb 18 up to 18.1.0 but it doesn't work on 18.1. 1 (without making any changes to the wwb settings, of the page or of the extension itself) but only to add information to the extension (movies and links) and you tell me that it is possible that my extension is wrong... now with a change to 18.1.1...
I don't allow myself to contradict you...
In order to send you a demo, I would have to delete all the movies from the demo...I will try...but you should know that I don't have another computer and I won't buy one....
Thanks for all!!
Dragos
Post by Dragos »
Thanks for all!!
Thanks for the demo. However, it to work for me:
Also, can you please answer this:
Dragos
Post by Dragos »
Yes i can ...i tell you 2-3 post upside and send a movie with how to open page properties.
Tooltip extension propertie? Yes.
For me no...maybe you use 18.1.0 ver. that work for me too. Demo or my page.
Thanks for all!!
Of course I am using 18.1.1
That is the how point of this conversation :?
Dragos
Post by Dragos »
:( Its same version from site?
Realy i dont understand why work in 18.1.0 and not in 18.1.1….
Thanks for all!!
Yes, it's the same version.
Which version of windows do you use?
Did you recently update richedit?
Dragos
Post by Dragos »
Windows 11 … No update Richedit
Thanks for all!!
In that case, I have no idea.
It works for me.
Maybe someone else who is reading this can try it, so we can be sure it not a 18.1.1 issue?
Dragos
Post by Dragos »
I find solution: wwb import settings from previous version. I use Revo to clean all including registry and reinstall after that. Ask me for i want to import settings from wwb 17 and i say NO. And now work again. Maybe uninstaller most clean all if want to reinstall procedure to work.
Thanks for all!!
