as you right said, is just a demo, internally, you can do many combinations/configurations
anyhow i just suggested the op a link to view and if applies, to ask questions
give him some time to think about all the available options
This is where you are wrong! As a designer & developer you SHOULD buy from yourself to test out all the functionalities of your site. That's why PayPal has SandBox option.HORIZON wrote:I always look at carts (any cart) from the viewpoint of an end user, as well as to the site owner. After all, none of us are buying things from our own sites..
Hi Adex will check that out.adex1 wrote:Hi,
Check my signature for Alternative eCommerce extension by one of the strong member of this forum.
Hi HORIZON - Quite a considerable response - appreciate that mate! and I think you may be right with Paypal Express.HORIZON wrote:Hi Colin. I looked at a few e-commerce solutions to use with WWB, but found George's Webshop Plus was the only one that allowed me to calculate the shipping cost BEFORE going out to PayPal. The Smartcart and Nopcart extensions fail miserably in that respect, as few customers are realistically going to log into PayPal just to know what the shipping charges are.![]()
With PayPal Express, if memory serves me correctly, it requires a correctly certificated SSL site, otherwise it 'falls over' during the checkout process, which is why I use standard PayPal as far less hassles.
There is a free javascript cart called Nopercart that allows you to set up shipping but that is a manual html entry for every product listed. Probably one of the best integrated cart solutions I have come across though, with a very sleek (and rapid) checkout.
I have moved onto responsive sites now and use Webshop plus with WWB10 and for the more product laden sites I use Opencart, although the latter ties you to rigid templates that limit you to tweaking colours rather than free design AND you have the added complexity of setting up SQL databases.
So yours does RZ?[RZ] wrote:should be: the only one <<in the list you tested>> that allowed... etcwas the only one that allowed me to calculate the shipping cost BEFORE going out to PayPal
otherwise you are meaning that this option is not available in any other e-com solutionand fyi the extension i suggested in the link i provided to the op has this option
Cheers Zinc!zinc wrote:Good choice Collin!!! Well done mate.
awesome RZ - thanks Mate![RZ] wrote:thank you for your kind mail
(you will be receiving an answer today, even i have ready an extra demo that can be useful for the proposed case)
Hi David,DavidQ wrote:Hi Colin,
I am looking into the current WWB ecommerce options for an upcoming project and wondered how you got on with your project? Did your choice of cart work out well for you? I'd appreciate hearing your thoughts.
Cheers,
David
You're welcome David - and agreed - Zinc's avid promotion of RZ's solution is not ruled outDavidQ wrote:Hi Colin,
Thanks for your reply. Yes there are a lot of options! It's a bit of a research black hole and I'm still investigating.
Cheers,
David
@colin, this really does not sound good, anyway i do not take it personal but lets say 'humorously'Zinc's avid promotion of RZ's solution is not ruled out
Ha Ha RZ - yup, I can definitely relate to Client's that are, as you say "not easy" - that test us - but that's often a good thing![RZ] wrote:@colin, this really does not sound good, anyway i do not take it personal but lets say 'humorously'Zinc's avid promotion of RZ's solution is not ruled out
take into account that zinc is not an easy client (and i mean it!), not less than the 70% of the introduced changes were made possible thanks to his avid and constant brain-pecking
@zinc, take it easy, i'm just joking about you
