Idea for Listing Businesses
Lasa
Post by Lasa » Fri Jul 19, 2019 3:29 pm
I want to list a small logo and business contact information with email.
what would be the easiest way to build it?
I need it to be responsive and easy to upkeep since we will be adding a lot of businesses daily.
Its just a listing no bells and whistles.
Cheers,
Lasa
Re: Idea for Listing Businesses
Post by Pablo » Fri Jul 19, 2019 3:51 pm
Maybe you can use the listview?
Lasa
Post by Lasa » Fri Jul 19, 2019 5:03 pm
Sounds right.
List view? put it in help and it came up nothing.
Where is it?
Lasa
Post by Pablo » Fri Jul 19, 2019 5:11 pm
You can find in the listview object in the toolbox (jQuery/Bootstrap).
It is also documented in the help.
Lasa
Post by Lasa » Sat Jul 20, 2019 10:13 pm
Thanks!
I just looked again in help and nothing comes up for listview?
If I search in the toolbox then yes it comes up,
just not in the help section.
Thanks.
Post by Pablo » Sun Jul 21, 2019 6:41 am
Help -> Content -> Toolbox -> jQuery UI/Bootstrap -> Listview
Search for 'listview' will also work.
