Text boxes on breakpoints
GrahamW
Post by GrahamW » Wed Jul 03, 2019 8:06 am
In version 14 if you had a text box in a layout grid and click it the box would automatically expand out to fit all the text. In version 15 if you click it nothing happens
Graham
Re: Text boxes on breakpoints
Post by Pablo » Wed Jul 03, 2019 9:13 am
Are you using the most recent update (15.0.1)?
If yes, then what are the exact steps to reproduce this behavior?
Fender
Re: Text boxes on breakpoints don't scale!
Post by Fender » Wed Jul 03, 2019 10:02 am
I'm using the build of 3-7-19
I tried this and the problem exist.
Here I've made a sample for you https://ufile.io/45cog3v7
Insert text in layoutgrid
make some breakpints
Now when you go to a breakpoint you have to scale the textbox to fit in the layoutgrid
instead of just clicking on the text
This fact made me look at the text behavior in the jquery accordion wich I use in a site.
THIS HAPPENS ALSO IN JQUERY ACCORDION WITH THE TEXT!
I have to drag out the text to see and change the text
Post by Pablo » Wed Jul 03, 2019 12:37 pm
Although this change was intentionally, I have made it now work again like it did in previous versions (hotfix 6)
GrahamW
Post by GrahamW » Thu Jul 04, 2019 2:49 am
Thanks Pablo all fixed now
Graham
Lasa
Post by Lasa » Thu Jul 04, 2019 9:06 pm
How do you add a hot fix, I've noticed the same thing..
Thanks,
Lasa
alan_sh
Post by alan_sh » Thu Jul 04, 2019 9:13 pm
Just download and re-install the latest s/w.
Alan
Lasa
Post by Lasa » Thu Jul 04, 2019 10:01 pm
Easy enough!
Lasa
