[rz] Pattern II *** UPD 2020-Jun-10 ***
Post by [RZ] » Wed Oct 16, 2019 12:39 pm
[rz] Pattern II v2.0.0.1
This extension allows to create a color and/or image based background pattern.
Some features:
- Optional color.
- Optional texture image.
- Selectable color and image order.
- Padding, radius and opacity level specific for both color and image.
- Additional global opacity level.
- Multi-instance in the page or within a container.
- RWD support (almost all features are breakpoint specific).
- Backward and cross-browser compatibility (rounded borders may not apply on some older browsers).
- Interacts with [rz] Background Images and [rz] Background Video.
- Lightweight and no jQuery required.
...and more!
HTML 4.01 Transitional
W3C compliant
DEMO
* New in version 2.0.0.1
- Fixed an instability handling target elements.
- Improved core.
How to use?
1. Drag and drop the extension in the workspace.
2. Resize it accordingly if the instance is defined as a standard object.
3. Select the color and the optional image.
4. Setup the other parameters according to your scheme.
5. Publish or preview.
Enjoy!
Re: [rz] Pattern II
Post by zinc » Wed Oct 16, 2019 12:40 pm
A fantastic extension with some extraordinary powers!!!
Re: [rz] Pattern II
Post by [RZ] » Wed Oct 16, 2019 12:43 pm
thanks for your kind feedback!
(and for supporting my work behind the scenes :)
Re: [rz] Pattern II *** UPD 2020-Jun-10 ***
Post by [RZ] » Wed Jun 10, 2020 11:53 am
- Improved core.
