[rz] Top Menu *** UPD 2017-Nov-15 ***
Re: [rz] Top Menu *** UPD 2016-Mar-30 ***
Post by [RZ] » Wed Mar 30, 2016 11:49 am
* New in version 1.0.2:
- Instances can be placed on the body page or within layers.
- Added support for instances on [deeply] nested objects (usually layers) and within wb-carousel, jQueryTabs, etc.
Re: [rz] Top Menu *** UPD 2016-Apr-17 ***
Post by [RZ] » Sun Apr 17, 2016 12:49 pm
* New in version 1.1:
- Optional images for the options with also optional ones for their different statuses.
- Optional images can have eight different positions for the main buttons and two for the slide.
- Optional images can be resized for a better appearance on retina-based devices.
- Extended panel positioning with 'push' effect.
- Horizontal and vertical menus can have their own appearance (icon-based/text-based/both).
- Vertical options have an optional 'equalize' feature that extends the icon/text alignment within its general alignment.
- Improved burger behavior on slower sliding setup.
- Improved logical z-order related to the page elements.
- Improved startup.
- Proprietary events: onopen, onopened, onclose, onclosed, onslide (this improves the interaction with other extensions like [rz] PFO and similar).
Post by zinc » Sun Apr 17, 2016 2:45 pm
This is part of the next generation of UI & UX tool. Great addition for a serious design.
Post by [RZ] » Sun Apr 17, 2016 2:49 pm
thank you zinc for supporting the hard work behind the scenes
feedback appreciated
Re: [rz] Top Menu *** UPD 2016-May-06 ***
Post by [RZ] » Fri May 06, 2016 9:22 am
* New in version 1.1.1:
- Optional smooth context fade-in/out with custom color and opacity when the vertical options are being opened.
- Fixed an unstable backward compatibility issue (missing menubar).
- Fixed minor scroll gaps 'on push contents' on some setups.
- Due to some limitations, the 'within-a-layer' instance feature has been [temporarily?] removed.
- Tweaked code for better performance.
Re: [rz] Top Menu *** UPD 2016-May-26 ***
Post by [RZ] » Thu May 26, 2016 6:31 pm
* New in version 1.1.2
- Indent effect for the vertical panel options (hover/push statuses).
- Smooth transitions for the indent effect.
Re: [rz] Top Menu *** UPD 2016-Jul-02 ***
Post by [RZ] » Sat Jul 02, 2016 8:47 pm
* New in version 1.1.3
- Optional 'fade while slide' effect for the vertical panel options.
- Improved (and extended) images/options alignments.
- Fixed a misalignment when options are mixed with and without images.
- Improved backward compatibility in 'current page detection'.
Re: [rz] Top Menu *** UPD 2017-Nov-15 ***
Post by [RZ] » Wed Nov 15, 2017 4:05 pm
* New in version 1.1.4
- Improved advanced options alignments/variants.
- Improved uniformity and compatibility when using borders and separators.
- Fixed a sizing issue when using fixed width for the horizontal menu.
- Fixed a slight vertical alignment issue in default position with bottom border in options.
- Fixed an issue formatting/equalizing the vertical image/option list on older browsers and improved cross-browser uniformity.
dnlyko
Post by dnlyko » Sat Dec 07, 2019 3:51 pm
One BIG Problem...
It does not seem to have the ability to add a scroll bar once you get more items in menu than the device can display on one screen.
This seems to be a common problem.
Post by [RZ] » Sat Dec 07, 2019 4:10 pm
if you are a legal user, just contact privately
w/ regards
