.ico files not saving to 'images' folder
andyp
Post by andyp » Mon Oct 19, 2020 6:15 pm
WB 16
Cant seem to get .ico files to save to the 'images' folder.
Making mistakes....and still learning as I go along.. and very grateful to those who know far more than me... :)
http://www.apgraphx.co.uk
Re: .ico files not saving to 'images' folder
Post by crispy68 » Mon Oct 19, 2020 6:43 pm
Hey Andy,
It works for me.
Do the following: go to Tools --> Options --> Publish
Under Target Folder For File types enter the following and save it.
andyp
Post by andyp » Mon Oct 19, 2020 7:28 pm
Yes that's what I have done... but not ending up there.
Set the extension as .ico and tried ico but doesnt want to do it?
The thing is that I am sure it previously did in WB15?
Post by Pablo » Mon Oct 19, 2020 7:41 pm
In the configuration, you will need to use 'ico', not '.ico'
See also crispy68's screenshot.
Post by crispy68 » Mon Oct 19, 2020 8:15 pm
pablo is correct. The extension should not contain the '.' (dot).
ico versus .ico
andyp
Post by andyp » Mon Oct 19, 2020 8:19 pm
Yes I originally used .ico which didnt work.. then tried ico which of course is not correct.
But it seems that for me its not working and it ends up withe html files and the file still works as interned.
Check the ico image and its definitely an icon image will try and do a screen capture
andyp
Post by andyp » Mon Oct 19, 2020 9:03 pm
View screen recording at https://youtu.be/Dy6twkEWrJ0
Post by crispy68 » Mon Oct 19, 2020 9:08 pm
You have it wrong. You have .ico and it should only be ico. Remove the dot. See my image above. There is no dot.
andyp
Post by andyp » Mon Oct 19, 2020 9:39 pm
Yes agreed that I made a mistake there.. but even set as ico its still not working for me
https://youtu.be/QPpXLvC38o0
Post by crispy68 » Mon Oct 19, 2020 9:52 pm
Where exactly is the .ico image being used? How did you insert it into the workspace? Are you inserting as a normal image?
andyp
Post by andyp » Tue Oct 20, 2020 1:08 am
Page Properties > Icons > and then set the path the the ico image
Post by crispy68 » Tue Oct 20, 2020 3:39 am
You are correct Andy. Based on where you are entering them, Icons added for the favicons are saved in the root directory. If the icon is inserted normally into the workspace via the image tool then it does work and saves it to the folder of your choosing.
I typically put my favicons in the root directory but I know using folders is an option. You may want to post this as suggestion for Pablo.
Post by Pablo » Tue Oct 20, 2020 6:20 am
This is behavior by design. Favicons are placed in the same folder as the page.
andyp
Post by andyp » Tue Oct 20, 2020 9:03 am
At least I have got an explanation as to why favicons are not included in the imaging filing as with other image formats by design :)
