Footer and master page relation
laros
Post by laros » Mon Oct 21, 2019 6:55 pm
Hello,
I am using a footer on master page. And than i use master page on some other pages.
Is it possible to set the footer always just under the last content. Because different pages have different size of content and therefore the height is different, so if i set a footer on 4000, than it will be on 4000 eventhough the content is up to 5000.
Any idea how to solve it?
Bluesman
Re: Footer and master page relation
Post by Bluesman » Mon Oct 21, 2019 7:47 pm
Hi Laros... if you set the Page footer to "Floating" I think it will do the trick.
"Make My Day"
See my Website
Post by Pablo » Mon Oct 21, 2019 8:13 pm
In master pages and master frame, the footer will automatically move after the content.
Related tutorials (with demos):
http://wysiwygwebbuilder.com/master_page.html
http://wysiwygwebbuilder.com/master_frame.html
laros
Post by laros » Mon Oct 21, 2019 8:19 pm
Thank you guys, problem solved. Magnificent!
Is it better that the menus are in the header or it doesnt matter?
Post by Pablo » Mon Oct 21, 2019 8:55 pm
It does not matter, unless you are using drop down menus.
onlye
Post by onlye » Mon Dec 30, 2019 4:57 pm
I have been using WWB for about a year now and have not used master pages yet. I am building a site that I want the Header and Footer to be the same on all pages and the center content will be different and will have different layouts.
I read the documentation and it looks like there are Master Pages and Master Frames that address this. Not sure I fully understand the difference.
Which should I use?
****** update ******
Well, I just finished the site and used Master Pages. It seems to work just like I wanted.
Still don't get the difference between Master Pages and Master Frames - yes I read the documentation on both.
THANKS!
Post by Pablo » Mon Dec 30, 2019 5:45 pm
