Some council
farins
Some council
Post by farins » Wed Aug 28, 2019 1:31 pm
Hi, im a new user of this nice tool. i just want ask some council/advice for finish my website in best way.
1: gallery...i need upload all my artworks,almost...25 images. and them have different aspect ratio and orientation. what i looking for is a responsive gallery who can show the thumbnails in flexible way for close all spaces from images without distortion.....Masonry gallery look like what im looking for, but first to buy it i wanna ask if its good for what i looking for....
2: after/before image...its a features i love, i try the extention but look like dont work at all...what i try to do its the effect visible in the picture this page: https://docs.chaosgroup.com/display/VRA ... ayDenoiser....how is possible archive one similar effect?
3: bookmark features work so good for avoid to scroll long pages, but look like in mobile version seem to be less precise, and always stop into a wrong place
Re: Some council
Post by Pablo » Wed Aug 28, 2019 1:57 pm
For an overview all available galleries please go to:
http://wysiwygwebbuilder.com/extensions.html
A demo of the masonry extension is also available.
Also note that the built-in gallery has many options:
http://wysiwygwebbuilder.com/photogallery.html
I am not familiar with the after/before extension. Please contact the developer for help.
Bookmarks go the exact position where you have placed them. It is a standard HTML feature.
If it does not work correct then you may have set an offset in the property of the bookmark.
farins
Re: Some council
Post by farins » Wed Aug 28, 2019 3:57 pm
thanks pablo
alan_sh
Re: Some council
Post by alan_sh » Wed Aug 28, 2019 4:49 pm
Have you looked at the photo collage ?
Alan
Williams
Re: Some council
Post by Williams » Fri Aug 30, 2019 12:38 pm
Yes that's right, i have tried to use this extension like a month ago with no luck :roll:
could you take a look at this extension Pablo and see what's wrong !!
Re: Some council
Post by Pablo » Fri Aug 30, 2019 1:06 pm
I'm sorry, I cannot give support on third party extensions.
Williams
Re: Some council
Post by Williams » Fri Aug 30, 2019 1:42 pm
can you create an extension like that Pable even paid one!!. i think this features is very useful.
Re: Some council
Post by [RZ] » Sat Aug 31, 2019 7:03 pm
Williams
Re: Some council
Post by Williams » Tue Sep 03, 2019 9:29 am
this is already possible
http://www.wysiwygwebbuilder.com/forum/ ... 53&t=76258
w/regards
That's AMAZING..
Is this responsive! Can i use it in different breakpoints!
Re: Some council
Post by [RZ] » Tue Sep 03, 2019 9:32 am
yes rwd
thanks for your kind feedback
Williams
Re: Some council
Post by Williams » Tue Sep 03, 2019 9:52 am
RZ, I couldn't find this extention under your list
http://www.magnawebstudio.com/shop/single.html
Is there a direct URL where i can find the extention and purchase it!!
Re: Some council
Post by [RZ] » Tue Sep 03, 2019 10:00 am
yes it is there
it is called [rz] Reveal Layers
if you have further questions pls get in contact privately
(i will be out 6+- hours)
