how is works with send email?
manuel_songokuh
Post by manuel_songokuh » Tue Aug 06, 2019 1:14 pm
hi
i did try template by coffetime, there is in area contact: email and not work to send email anymore..what is problem from?
Re: how is works with send email?
Post by Pablo » Tue Aug 06, 2019 1:21 pm
The form in the template is just a layout example, the form is not yet configured . If you want to process the form then you will need to enable the form script.
Related FAQ:
viewtopic.php?f=10&t=32967
