Can I have V. 14 & 15 installed at the same computer?
Markus
Post by Markus » Sat Jul 06, 2019 9:38 am
Hello Pablo,
I just bought version 15 (I am user of version 14).
Can I install version 15 x64 parallel to my existing version 14 x86 on my Windows 7 x64Computer?
Are there known side effects?
Are the settings shared?
Thank you for further informations.
Kind regards
Markus
GrahamW
Re: Can I have V. 14 & 15 installed at the same computer?
Post by GrahamW » Sat Jul 06, 2019 9:39 am
I have 12, 14 and 15 all installed.
Bear in mind anything saved in later versions won't open in earlier versions
Graham
Post by Pablo » Sat Jul 06, 2019 10:13 am
Yes, you can have both versions on the same computer.
They do not share the same settings, but they do share the same publish data, templates, extensions. Unless you configure a different system folder (in Tools -> Options-> Files & Folders)
Markus
Post by Markus » Sat Jul 06, 2019 11:46 am
Great, thank you both for your answers. :)
