*** SOLVED *** wwb15: not work with site template: iphone..
manuel_songokuh
Post by manuel_songokuh » Mon Jul 01, 2019 9:03 am
hi
i try to use template "iphone": http://www.wysiwygwebbuilder.com/suppor ... ml#slide-1
and open with template and crash , reopen in view is empty.. not work..why?
preview in browser is bad and disorient images...
Re: wwb15: not work with site template: iphone..
Post by Pablo » Mon Jul 01, 2019 9:11 am
It seems to work correct for me.
Can you please provide more information?
What are the exact steps to make it not work?
manuel_songokuh
Post by manuel_songokuh » Mon Jul 01, 2019 9:21 am
ok see here screen record:
http://sendvid.com/e5jcbksv
Post by Pablo » Mon Jul 01, 2019 9:30 am
Do you have the latest update installed? (hotfix 4)
http://wysiwygwebbuilder.com/download.html
manuel_songokuh
Post by manuel_songokuh » Mon Jul 01, 2019 9:53 am
yes, i did installed hotfix..
Post by Pablo » Mon Jul 01, 2019 9:56 am
Did you install it today?
What is the date in the 'About Box'?
What is your Windows version?
Do you have this problem with any of the other templates?
manuel_songokuh
Post by manuel_songokuh » Mon Jul 01, 2019 10:58 am
yes today i install wwb15, windows is 7 64bit, version 15 (june 30 2019), wwb15 64bit
Post by Pablo » Mon Jul 01, 2019 11:05 am
I'm sorry, I cannot find anything wrong.
I tried it myself on 4 different computers and it works for me.
manuel_songokuh
Post by manuel_songokuh » Mon Jul 01, 2019 11:22 am
yes same problem with other different template..
i try update windows..dont know..i try..
manuel_songokuh
Post by manuel_songokuh » Tue Jul 02, 2019 10:18 am
hi now is worked , that needed update of windows service (.net, etc,etc,etc) after rebbot it is works.. :D
Post by Pablo » Tue Jul 02, 2019 10:24 am
Thanks for clearing that up.
