Text on carousel incorrect on WB15
GrahamW
Post by GrahamW » Sat Jun 29, 2019 12:59 am
I have text that comes in on my images on the WB carousel and its perfect on WB14
See link here: https://www.grahamscomputers.net/
but when I open and preview the project in WB 15 the text that comes over the carousel is all on the left even though it is all center aligned .
To see the difference in WB 15 here is a link to project zip
https://www.grahamscomputers.net/Graham ... s 2019.zip
Graham
h3rnan
Re: Text on carousel incorrect on WB15
Post by h3rnan » Sat Jun 29, 2019 1:13 am
I downloaded your project ... I have a suggestion, not the subject
In it I see the credentials of your hosting you left entered ..., from this link all can download and enter your hosting. If they are real ... delete that now!
Hernán Pena
Web Developer / IT Administrator
GrahamW
Post by GrahamW » Sat Jun 29, 2019 1:35 am
Thanks h3rnan I wasnt even aware that was in there
Graham
Post by crispy68 » Sat Jun 29, 2019 3:40 am
Hey Graham,
I looked at your demo and to me it appears there is some issue with the carousel being set to 'full width & floating' with the 'responsive Carousel' checked. If you uncheck the box it seems to work correctly for me. Pablo will have to weigh in on this.
On another note, I noticed you are using layout grids but you have the page alignment set to 'center horizontally'. When you are using floating layouts, you do not want to set the page alignment to this. Set it to 'do not center this page'.
GrahamW
Post by GrahamW » Sat Jun 29, 2019 4:13 am
Thanks Ron,
I will make that change on my end with the center page but wont upload it yet so Pablo can have a chance to check out what is going on.
Graham
Post by Pablo » Sat Jun 29, 2019 7:33 am
Thanks for sharing the project.
The issue should be fixed in the latest build (6/29/2019)
