14.3 64 bit version install issue
ShawnInPaso
Post by ShawnInPaso » Sat Dec 22, 2018 7:19 am
Hello,
Upon trying to install v14.3 64 bit version I get an error message. I have closed all programs prior to install, then tried again after rebooting my Windows 7 PC. The v14.3 32 bit version installs fine.
The error message is:
"The program can't start because api-ms--win-crt-convert-l1-1-0.dll is missing from your computer.Try reinstalling the program to fix the problem"
I'm fine using the 32 bit version but thought I should mention this error in case it's not unique to my computer.
Cheers,
Shawn
Re: 14.3 64 bit version install issue
Post by Pablo » Sat Dec 22, 2018 7:48 am
It sounds like you did not install the run-time components.
See the notes:
viewtopic.php?f=1&t=77283
Paracelsus
Post by Paracelsus » Sat Dec 22, 2018 12:36 pm
I am getting a similar message while trying to install v.14.3.0, stating that "mfc140u.dll" cannot be found.
Version 14.2.2 was installed without this error message, so I am puzzled why 14.3.0 is missing "mfc140u.dll" which 14.3.2 apparently did not need.
Do I have to download it from somewhere?
Thanks!
Post by Pablo » Sat Dec 22, 2018 12:47 pm
Maybe you have 'accidentally' installed the 64bit version?
Did you install the run-time components?
