Blocks
Patrik iden
Blocks
Post by Patrik iden » Fri Sep 14, 2018 12:54 pm
Hello, wy can't i set the Vertical possistion on some blocks (Layout Grids)?
Thank you.
Re: Blocks
Post by Pablo » Fri Sep 14, 2018 1:13 pm
Most blocks use layout grids, which means they were designed for floating/flexible layouts.
You can use the arrange tools to move blocks up and down the page.
Related tutorials:
http://wysiwygwebbuilder.com/blocks.html
http://wysiwygwebbuilder.com/layoutgrid_part1.html
Patrik iden
Re: Blocks
Post by Patrik iden » Fri Sep 14, 2018 9:49 pm
OK, i'm adding a text, but text is always aligned to the top, i can set padding but then the hamburger bars get outside of the block.
Re: Blocks
Post by Pablo » Sat Sep 15, 2018 6:14 am
Did you read the tutorials?
Patrik iden
Re: Blocks
Post by Patrik iden » Sat Sep 15, 2018 6:24 pm
no
Re: Blocks
Post by Pablo » Sat Sep 15, 2018 8:41 pm
Please do. The tutorials explain the difference between floating and absolute/fixed layouts.
