Insert a link to a specific area inside a picture
Bluesman
Post by Bluesman » Thu Aug 09, 2018 8:23 pm
Hi... I have used this future before, but don't remember if it was with WWB or the software I had before :D
Anyhow… is it possible to dedicate a specific area inside a pic/photo with chapes as rectangle or circle, to make a link?
"Make My Day"
See my Website
WWBman
Re: Insert a link to a specific area inside a picture
Post by WWBman » Thu Aug 09, 2018 9:20 pm
Do you mean the Image Map with Hot Spot(s)?
Insert > Image > Image Map
Bluesman
Post by Bluesman » Thu Aug 09, 2018 10:08 pm
Ahh, was looking to that, but probably aproached from wrong direction. I thought you could apply to an existing image on the page, but with this you have to insert the immage to the tool, I presume? :D I will test again.
Tnx WWBman
"Make My Day"
See my Website
Bluesman
Post by Bluesman » Fri Aug 10, 2018 3:15 am
Yes that was the tool. But unfortunately it did not work "responsive"
"Make My Day"
See my Website
Post by Pablo » Fri Aug 10, 2018 6:36 am
Unfortunately the Image Map (which is a a standard HTML feature) is not responsive. You can only define one set of (fixed) coordinates.
Bluesman
Post by Bluesman » Fri Aug 10, 2018 12:35 pm
Thanks for the answer Pablo... as you noticed I put the issue/mther to the "Suggestion" section.
"Make My Day"
See my Website
