Image Fade
RiaanN
Image Fade
Post by RiaanN » Fri Jun 22, 2018 8:43 am
Good Day
The image +fade effect as I see it, takes the image and then fade it from the top downwards, it there a way to reverse the fade direction
Regards
Re: Image Fade
Post by Pablo » Fri Jun 22, 2018 8:49 am
You can set the gradient style in the gradient settings.
RiaanN
Re: Image Fade
Post by RiaanN » Fri Jun 22, 2018 8:58 am
Sorry Pablo I dont understand.
The image is used as the background in 2 layers. I am trying to create the effect that the image is fading away in layer 1 and then pic up in layer 2 and not create a line between the 2 images if you understand what I mean.
Re: Image Fade
Post by Pablo » Fri Jun 22, 2018 9:29 am
RiaanN
Re: Image Fade
Post by RiaanN » Fri Jun 22, 2018 9:42 am
Wow - So easy
Thank you very much !
