PayPal Mini Cart
Re: PayPal Mini Cart
Post by BaconFries » Sat Apr 07, 2012 9:06 pm
No sorry they are hard coded into the extension...I might need to take a look at this again and see if I can improve on it...it getting the time to do this but if I can I will...
supersonictt
Post by supersonictt » Sat Apr 07, 2012 9:10 pm
Thanks for your replies :)
Take your time on that, no rush mate :)
Patr100
Post by Patr100 » Sat Apr 07, 2012 9:17 pm
BaconFries wrote:No sorry they are hard coded into the extension...I might need to take a look at this again and see if I can improve on it...it getting the time to do this but if I can I will...
Thanks for your work on this ext.It would be really good if you could make the cart appear to the right by default as surely this is the accepted convention for most similar carts - I don't know of any that hover/stick to the left. It just doesn't feel natural nor intuitive to be on the left.
bourin
Post by bourin » Wed Apr 11, 2012 6:40 am
Patr100 wrote:Thanks for your work on this ext.It would be really good if you could make the cart appear to the right by default as surely this is the accepted convention for most similar carts - I don't know of any that hover/stick to the left. It just doesn't feel natural nor intuitive to be on the left.
Our commercial "PayPal Mini Cart" Release http://www.mjh-software.org/wwb-extensi ... rce-02.php allow this to set via Display Edge - The edge of the page the cart should pin to. Set to left or right.
professional WWB extensions for tables, MySQL, Excel, e-commerce, measurement, gallery, file uploader, ... - produced from german and thai software engineers
Post by zinc » Wed Apr 11, 2012 7:20 am
Sorry to butt in but it does appear on the right corner.
Good news everyone!
Patr100
Post by Patr100 » Wed Apr 11, 2012 1:42 pm
bendigo wrote:Sorry to butt in but it does appear on the right corner.
Is that in answer to Bourin or me?
By default it appears on the left. Until you modify this action.
bourin
Post by bourin » Thu Apr 12, 2012 1:16 pm
BaconFries wrote:@iamafireman insert the code below in Page HTML between<head></head> tags* set the z-index to what you require but I think 100 should be enough....
<style type="text/css">
#PPMiniCart {
position: relative !important;
z-index: 100 !important;
</style>
I have tested the setting for z-index, based on infos from https://github.com/jeffharrell/MiniCart/pull/67
<head>
   #PPMiniCart form { z-index: 100; }
</style>
</head>
and, based on infos from https://github.com/jeffharrell/MiniCart
<head>
   #PPMiniCart { z-index: 100; }
</style>
</head>
result: all don't work. Only a
<div id="wb_PayPal-Mini-Cart" style="position:absolute; ... z-index:100;" align="left">
<script src="minicart.js" type="text/javascript"></script>
   PAYPAL.apps.MiniCart.render({
      displayEdge: 'right',
      edgeDistance: '50px',
      cookiePath: '/',
      paypalURL: 'https://www.paypal.com/cgi-bin/webscr',
      strings: {
         button: 'Button',
         subtotal: 'Subtotal',
         discount: 'Discount',
         shipping: 'Shipping'
</script>
</div>
generate a useful handling. There are to ways to set the z-index:
(1) into WWB project side via STR++ - mostly forgot
(2) after wwb project publis with an outside "search and change" software
Post by BaconFries » Thu Apr 12, 2012 2:23 pm
@ bourin what version of the minicart.js file are you using in your extension????
the code below is for the latest version of the minicart.js I was in contact with the author of the script regarding a issue regarding z-index order and this is what HE recommended so before being critical regarding this please check that YOU are using the latest minicart.js which this fix is for and not previous version of the script.....
#PPMiniCart {
</style>
bourin
Post by bourin » Thu Apr 12, 2012 2:31 pm
I'm use version 2.0.6 = jeffharrell-MiniCart-2.0.6-0-gbc27f32.zip from here https://github.com/jeffharrell/MiniCart/archives/master
bourin
Post by bourin » Fri Apr 13, 2012 8:59 am
I'm found today also a jeffharrell-MiniCart-2.0.6-18-gaaf3ef1.zip without any effort for the z-index problem, don't work.
pavlos1
Post by pavlos1 » Sun May 13, 2012 9:24 am
Finally, is there a finished, completed extension version? As I can see, there are code pieces here and there, in various posts.
Has someone completed this useful extension?
Paul
Post by BaconFries » Sun May 13, 2012 10:50 am
@pavlos1 the extension by kevin is already available to download at the very first post of this topic it can be seen below the screenshot a clue is Download at http://www.mediafire.com
viewtopic.php?f=42&t=25316
pavlos1
Post by pavlos1 » Tue May 29, 2012 7:00 pm
Thank you BF, it works smoothly with wysiwyg paypal buttons.
However, I need to make some modifications on the js script, like colors, etc., but I can't locate it. Where can I find it?
Thanks,
Paul
Post by BaconFries » Tue May 29, 2012 8:49 pm
To make any changes to the js file you will need to open it with a HTML Editor scroll down to line
87 function createCart() here you will find some code to allow you to make the changes...note if you open the extension again in wb then these will be lost and you will have to repeat.
pavlos1
Post by pavlos1 » Wed May 30, 2012 6:12 pm
BF, I know I have to edit the js file in an html editor, but I can't find this js file.
Where is this file?
Thank you
