JW Image Rotator 3.17 ***Update 19/09/13***(Depreciated)
Re: JW Image Rotator 3.17 ***Update 14/11/11***
At present I am unable to test this due to not having access to PC and answering by phone/ tablet. When inserting images ensure that there names are all valid no spacing no special charcters. The Title you refer to is the name of the imge so if the image name is mybeautifulimage.jpg then the title is My beautiful image minus the file extension .jpg. The Image Description is just a simple descrition of what the image looks like so if it is an Ferrai racing then you would insert something like My beauiful Ferrari racing. As mentioned I am not able to test or assist furthet due to not having access to PC to give you a better answer sorry..
Thank you, although can I wait until you have access to a PC and check into my query? As said, creating a "1. Image Rotator Playlist" is simple enough, but "2. Slideshow Settings" seems confusing - not the actual settings per se, but that "Add" and "Edit", etc., implies (at least to me) adding more Images, when I would have thought that once the Playlist is created in "1." there would be no need for further such adding in "2.". Thank you.
Sorry, but just don't get how this thing works (see above). Please help, anyone.
Anyone want to throw some light on this?
Ok I can finally try and answer you. What is confusing in the Slideshow settings?. There is no mention of adding anymore images than you have previously done so in the image playlist. The only other image you can add is a logo.The use of a logo depends on what the Image rotator is displaying, lets say you have made a site for a Photographer, and he/she wishes there logo to be displayed in the image rotator, then you can add a logo on top of the images, this would work like a watermark, this is all this setting is for. All other settings are how the rotator should function this includes any effects such as transitions, autostart, the rotators color how it will look. There is only one other reference to the images and that is the width and height these are set here in the slideshow settings and not in the Playlist because they do not get stored in the playlist xml file, they get embeded in the page html, where the images get called from a xml file along with the oter settings. Hope this is a little clearer to you.
The extension can only be downloaded and installed via the extension manager in WB9. Or you can manually download from the following.
http://extensions.wysiwygwebbuilder.com/
Please also note that this extenson is now provided "As IS" I no lionger support this as it is no longer supoorted bt the original author.
Re: JW Image Rotator 3.17 ***Update 19/09/13***
***19/09/2013***
Please note that this extenson is now provided "As Is" I no lionger support this as it is no longer supported by the original author BF.
