5 Star + Thumb + Hearts Rate Extension + translate variable
Eddy
Post by Eddy » Tue Apr 21, 2009 8:30 pm
Star rate extension with translate variables and select option for stars,thumbs or hearts!
I have made new png star images for a bether quality but in IE6 the
pngfix for transparentie das not work with the png images.
Developer: Gr0w
http://gr0w.com/
Extension builder: Eddy.
Download Star rater with translation variables for WB 6.5.(please read the included pdf )
http://www.mediafire.com/file/m51tz2t0g ... ate_65.zip
Star rate extension for WB 6.5.
Download Star rater (please read the included pdf )
http://www.mediafire.com/file/yoz11manyji/Star Rater_65.zip
Thumb - rate extension for WB 6.5.
Download Thumb rater.(please read the included pdf )
http://www.mediafire.com/file/oojczaoid ... ter_65.zip
Hearts rate extension for WB 6.5.
Download Hearts rater.(please read the included pdf )
http://www.mediafire.com/file/momzzozm5yd/Hearts Rater_65.zip
You can use more than one rate on every page.
If you use different rate layouts than you need to use pages in folders to not overwrite the php file.
For every new rate change the ID
You can use in total 80 ratings on your website withoud using folders with the same rating layout.
If you use folders than you can use in every folder with pages also 80 ratings ,with for every new folder with pages a different rating layout.
Every new rate ID generates a new page on your server for the rate results with the same ID as your rating.
How to change the rate images.
There is a folder with name img uploaded to your server,in there are the images for the rate extension .
Change these images to what you like but they must have the same name and image extension .png
Use if possible the same width as the original rate image the height is not so important.
The differents between the translate version and the other three.
The first with translation have stars,thumbs and hearts.
For different rating layouts in your website you have to use pages in folders.
The other three are english but have different names for the php and rate savings file.
You can use al three english versions on one page or website if I did not make a mistake in the codes :wink:
Every next rate object must have another ID number in all versions!
star1
star2
star3
thumb4
hearts5
star57
Post by star57 » Tue Apr 21, 2009 8:34 pm
Awesome Job Eddy~! Thanks
Post by zinc » Tue Apr 21, 2009 8:39 pm
Nice one Eddy!!!!
Eddy
Post by Eddy » Tue Apr 21, 2009 8:43 pm
Was a lot work,I did make new images because the original have a white background what you not can use on backgrounds with another color than white.
I did search for a solution with IE6 transparentie but no luck :?
If needed for IE6 users can always make new images with the same color as the page background,but I think there are now only a few people left what use IE6, thus not realy a problem.
Post by BaconFries » Tue Apr 21, 2009 9:16 pm
Very Nice Eddy
genieuk
Post by genieuk » Tue Apr 21, 2009 11:28 pm
Nice extension. I was going to attempt to try an extension similar like this,
Now i won't have to.
Thanks Eddy!
Regards,
Mathew
star57
Post by star57 » Tue Apr 21, 2009 11:49 pm
Honest, if anyone has IE 6.... UPGRADE already! if you have to stick with IE 6 because your program vendor has stated that they have no fix, Fire them and get a new vendor. just my pennies worth!
me.prosenjeet
Post by me.prosenjeet » Wed Apr 22, 2009 5:31 pm
Nice one eddy!
will download
www.Lucknowwebs.com
DarrenH
Post by DarrenH » Wed Apr 22, 2009 9:27 pm
Excellent work (again) Eddy!
:D
One quick question - can you also change the images of the stars in the extension - eg to thumbs up, or something else just in case the star rater has to go onto a site that thumbs (or something else) would be more appropriate.
Doesn't matter if you can't - just wondered before I utilised.
Excellent Eddy!
DarrenH
Post by DarrenH » Wed Apr 22, 2009 9:35 pm
:D :D :D :D
Excellent Eddy!
madebyibloo
Post by madebyibloo » Thu Apr 23, 2009 9:02 am
This is a nice extention! am loving the thumbs!
Great work Eddy
Cheers,
SUB
star57
Post by star57 » Thu Apr 23, 2009 10:01 pm
great Extension
Eddy
Post by Eddy » Thu Apr 23, 2009 10:23 pm
I`am improving this rate extension with more options,just wait :wink:
star57
Post by star57 » Thu Apr 23, 2009 10:24 pm
Eddy wrote:I`am improving this rate extension with more options,just wait :wink:
Better, no way!
Eddy
Post by Eddy » Sun Apr 26, 2009 8:26 am
New updates ,look in the first post :wink:
