Bcastr Slideshow Extension
protectourlands
Post by protectourlands » Sun Mar 22, 2009 5:23 am
I really like this extension. It is exactly what I am looking for, except I cannot get the description feature to work. Only the title will appear. Is the description feature active?
star57
Post by star57 » Sun Mar 22, 2009 1:01 pm
protectourlands wrote:I really like this extension. It is exactly what I am looking for, except I cannot get the description feature to work. Only the title will appear. Is the description feature active?
I never used the description field, the slides I used it on was like information slides that I had photoshoped already!, I tested it and no does not work..
protectourlands
Post by protectourlands » Sun Mar 22, 2009 4:27 pm
Sneil69, is there any way to activate the description entry in this extension? Also add basic text attributes (font, bold)?
I'm looking to be able to build slideshows like these with your extension:
http://www.stopgreenpath.com/slideshows/buildingss.html
I had to build each photo with description text in Photoshop before importing into WB slideshow. I'm trying to get around this.
Post by zinc » Sun Mar 22, 2009 7:39 pm
protectourlands
As far as I know that is not possible, Version of 4.0 of Bcastr does have this feature but I have not implemented that and don't have the time to do this.
See http://www.ruochi.com for more details.
Sorry. :cry:
star57
Post by star57 » Sun Mar 22, 2009 8:34 pm
protectourlands wrote:Sneil69, is there any way to activate the description entry in this extension? Also add basic text attributes (font, bold)?
This extension will work, they have each picture on the website as a JPG, so create your pic with titles and Dont use the title info or the buttons in the slideshow, Works great for the ones I have.
protectourlands
Post by protectourlands » Mon Mar 23, 2009 12:35 am
Star57
That's my website. I built that slideshow. I'm trying to avoid having to do this. I have many of these to build and will have to update the text frequently.
Sneil69
Thanks for the info.
star57
Post by star57 » Wed Mar 25, 2009 10:50 am
I found a script that might work for you!
http://javascript.internet.com/text-eff ... aphic.html
now if one of the great extension masters can make this, would be great!
protectourlands
Post by protectourlands » Wed Mar 25, 2009 3:07 pm
Great find star57. This would make a great extension, especially if a fade option were added. I really like the fact you can add a link in the text.
The extension would be perfect if text attributes like font, bold, and italics were added.
Thank you so much star57.
Post by zinc » Wed Mar 25, 2009 5:27 pm
protectourlands
I agree, Originally I did this extension for a clients website and it was not the intention to release but then I did, Now I swampted with soooo much work that I simply do not find the time to improve it. Version 4.0 has many cool features and is heavily XML driven. I would welcome anyone who would like to try it. :lol:
Post by BaconFries » Wed Mar 25, 2009 6:34 pm
HI protectourlands
Regarding the script star57 gave link to it may just be possible to make into extension I have looked at it I know that I cant add the fade this would need extra js and I am not a js writer. The only other issue I see is you will need to add images one by one and same for descriptions etc. I did try using a xsl so that it it would call images from a xml but instead of displaying one image on page it displayed all the images inserted at once
:( I will let you know the results...
Edit
As Eddy has pointed out this script cannot be used in the making of extension due to copyrights...sorry I will leave it due to this
Eddy
Post by Eddy » Wed Mar 25, 2009 6:58 pm
http://www.webmediabrands.com/corporate/legal.html
1. Copyright, Licenses and Idea Submissions.
Domestic and International copyright and trademark laws protect the entire contents of the Site. The owners of the intellectual property, copyrights and trademarks are WEBM, its affiliates and subsidiaries or other third party licensors. YOU MAY NOT MODIFY, COPY, REPRODUCE, REPUBLISH, UPLOAD, POST, TRANSMIT, OR DISTRIBUTE, IN ANY MANNER, THE MATERIAL ON THE SITE, INCLUDING TEXT, GRAPHICS, CODE AND/OR SOFTWARE
Post by BaconFries » Wed Mar 25, 2009 7:20 pm
Thanks for pointing this out Eddy looks like if you want to use it needs to be used "AS IS" so no point in porting over to a extension :( pity..
protectourlands
Post by protectourlands » Wed Mar 25, 2009 8:15 pm
This is a bummer.
I must have checked into 20 or more flash slideshow programs and none of them allow descriptions below the picture. I'm really amazed by this.
I thank you all for your efforts. I really do appreciate it.
Jim
Eddy
Post by Eddy » Wed Mar 25, 2009 9:24 pm
Sorry,I cannot change the rules from that website,but you can use the script how it is .
Maybe this helps,
The image urls and text go`s in the HTML object.
The nice thing is your images wil al in the images folder on your server.
Insert first al related scripts in your page.
Insert the code from newsDisplay.js in notepad and save as newsDisplay.js
Use the build-in file publischer to select and publisch the file together with the page.
For the vieuwer,
1)insert the images on your page.
2)copy the image path (images/imagename1.jpg)
3)paste the image path in your script and change width and height
4)type the text.
5)upload all,after upload all remove the images from the page and upload again,now are all your images in the images folder on your server.
This in HTML object.( i have removed the read more code)
<ul id="news">
  <li><img src="images/imagename1.jpg" width="200" height="150" alt="Picture 1">
    <p>Claritas est etiam processus dynamicus, qui sequitur mutationem consuetudium lectorum.</p>
  </li>
  <li><img src="images/imagename2.jpg" width="200" height="150" alt="Picture 2">
    <p>Eodem modo typi, qui nunc nobis videntur parum clari, fiant sollemnes in futurum. <p>
  </li>
  <li><img src="images/imagename3.jpg" width="200" height="150" alt="Picture 3">
    <p>Mirum est notare quam littera gothica, quam nunc putamus parum claram.</p>
  </li>
</ul>
star57
Post by star57 » Thu Mar 26, 2009 12:12 am
Thanks Eddy,
The legal notice is correct, and we are not changing anything, just making it WWb user freindly! Just as any script.
BUT I have contacted the site and the Maker, for approval and will give you an update on the outcome.
As long as the Website Links in the code is not changed, no problems. Will post the reply from the company!
