Webshop Plus! v.3.2 for WWB8
richardgo
Re: Webshop Plus! v.3.2 for WWB8
Post by richardgo » Fri Sep 28, 2012 2:14 pm
Hi Naval,
First of all I like to thank you for the good work you are doing and have done!
I only have one question, would there be any possibility that you will add the payment type iDEAL to the shopping cards? It is a very common method of payment in The Netherlands and would be great to have this included because I really want to use your tool.
Hope you can help me out?
Kind regards,
Richard
Navaldesign
Post by Navaldesign » Fri Sep 28, 2012 2:30 pm
I'm not familiar with Ideal. From what I have heard about Ideal, there is no standard solution for implementation as it depends on the actual payment gateway.
www.dbtechnosystems.com
Navaldesign
Post by Navaldesign » Tue Oct 09, 2012 3:33 pm
Yes, but what would you need Webshop Plus for then ?? I mean, the whole idea is to store all data: order details, customer details, delivery details, potential custom details and files etc. and be able to review them, list them, export in Excel, print, edit as required. If you do (it is possible but with some code amendments) what you suggested, all this data will not be even provided by the customer. So you are abolishing the cart features...
To do what you want, use the standard PayPal cart instead.
Patrik iden
Post by Patrik iden » Tue Oct 09, 2012 9:07 pm
I think you could modify the Paypal cart a little have a look here:
https://github.com/jeffharrell/MiniCart#readme
https://minicart.paypal-labs.com/#tab=advanced
hlohmeyerphoto
Post by hlohmeyerphoto » Sat Oct 20, 2012 1:11 pm
How do I change the "option, price variation" to a percentage increase instead of a fixed price? Thanks.
Navaldesign
Post by Navaldesign » Sat Oct 20, 2012 2:35 pm
hlohmeyerphoto wrote:How do I change the "option, price variation" to a percentage increase instead of a fixed price? Thanks.
I'm sorry, this would require heavily modifying the code.
hlohmeyerphoto
Post by hlohmeyerphoto » Sat Oct 20, 2012 2:47 pm
Thanks for the quick reply. So far this is great. Just battling with my own learning curve.
adrian5750
Post by adrian5750 » Fri Nov 09, 2012 2:34 pm
HI
Just trying out Webshop Plus.
Have followed the instructions in the pdf & created a cart folder & uploaded the 'admin' folder into it.
Cart has 755 and admin has 755 (was 644 but that didn't work so tried changing it !)
I can access the backend admin screen, and change the password etc, but, when it tries to save the info I get "
"Cannot create file config.php ! Please check folder permissions or contact your hostin company."
Any ideas ??
Adrian
*************Update***************
Setting permissions on config.php to 777 seems to work - but is this safe ??
I had similar issues with uploading files a few weeks back - the 755 permissions on the upload directory didn't work -
but 777 did...??
Adrian
Navaldesign
Post by Navaldesign » Fri Nov 09, 2012 4:18 pm
All files that could allow changing settings and details, are password protected, so yes, it is safe.
adrian5750
Post by adrian5750 » Fri Nov 09, 2012 4:51 pm
Navaldesign wrote:All files that could allow changing settings and details, are password protected, so yes, it is safe.
Ah, thanks for that....
Having spent come time in 'chat' with my hosting company - it appears that it's a known issue, and it's about file ownership rather than permissions.
In my particular case (shared Apache server under linux), they recommend changing the PHP5 setup so that it runs as a CGI application, then emailing support to request that ownership of the files in that domain are changed...
Apparently, if new domains are set up with 'run PHP5 as CGI' then there's no need to request the change of ownership, as that will be set automatically.
This explains the hassle I was having with the 'upload file from a form' thing a couple of weeks ago...
I'm only recording the details in case they might help somebody else with the same problem...
Adrian
Navaldesign
Post by Navaldesign » Fri Nov 16, 2012 12:10 pm
Pls post the actual URLs for working and non working pages.
Navaldesign
Post by Navaldesign » Fri Nov 16, 2012 5:55 pm
Pls forward the project through my contact form. Unfortunately, just looking at the page code through the browser, doesn't help as the PHP code is not displayed.
Navaldesign
Post by Navaldesign » Sun Dec 02, 2012 8:41 pm
If you look better, there is a note that you can set Quantity to 0 to remove an item from the cart.
Navaldesign
Post by Navaldesign » Sun Dec 02, 2012 8:50 pm
I will consider this for the next update....
kevinp
Post by kevinp » Wed Feb 20, 2013 9:18 pm
Hi Naval,
Not sure if this has been asked before so I apologise if it has. Is it possible to make the thankyou page auto continue to PayPal without having to click the button but still send the emails. It seems to cause some confusion even though the page clearly states that the button needs to be clicked. I'm afraid I'm a bit rusty on coding as its been a while. It needs to auto activate the button on page load to pass the form details but this doesn't seem possible. Any pointers would be appreciated.
