Webshop Plus! v.2.0 for WWB7
kevinp
Re: Modified version of the WB Webshop!! Webshop_plus
Post by kevinp » Sat Mar 19, 2011 9:51 am
Normally I'd agre, it's not really worth it for the standard cart but the problem is also present on the altered html mail cart and appears to happen with alarming regularity. People do choose their country but then click 'checkout' without using the recalculate button hence the tax and shipping are wrong resulting in somewhat of a mess. For my own site (where I've also made use of the cart) I'm in the process of going back to the mini cart option but unfortunately the client requires the html E-mail/packing slip so I'm kind of stuck with the current configeration.
Cheers
Kevin
Navaldesign
Post by Navaldesign » Sat Mar 19, 2011 12:16 pm
Hi Kevin,
I'll see if I can implement an Ajax routine to automatically update the cart on country selection or, at least, to force cart refreshing.
I'll keep you posted.
www.dbtechnosystems.com
Navaldesign
Post by Navaldesign » Sat Mar 19, 2011 3:00 pm
Hi Kevin,
You have a mail with the solution.
Patrik iden
Post by Patrik iden » Sun May 08, 2011 10:03 am
Ohh are you selling that plugin now?
kevinp
Post by kevinp » Thu Nov 17, 2011 8:19 pm
Hi ponderosaprinting/Naval
Would it be possible to use a Combobox instead of a textbox for the quantity. You could then set the values as you wanted e.g. 5, 6, 7, 8, 9 etc. I'm sure I've used this method before, I'll look through my files and see if I can find it.
Cheers
Kevinp
UPDATE:
Yes it is possible. I found a site where I've used this method. Swap the Quantity text box on your form for a combobox with the same name. I'll try and sort out a demo.
Navaldesign
Post by Navaldesign » Thu Nov 17, 2011 8:44 pm
Hi Kevin,
Yes, this is possible, BUT to change the price you need a Javascript that will change the value of the cart "price" hidden field (onchange event associated to the quantity selection).
Or, as I mentioned, an amendment to the code.
supersonictt
Post by supersonictt » Sat Dec 10, 2011 11:40 pm
Hello,
Sorry for this question (that might be asked before, I still haven't read all the thread, and I will do soon)...
There is a big possibility to re-design a website for a client, and everything is easy for me. The client wants to implement an online shopping system (his company sells sweets to international countries through the website and not locally).
What I want to ask is:
1. The webshop plus includes paying using Visa and Master card, is the transaction processed directly? I mean, does it have to be through a bank or something?
2. In order to protect the transaction, there should be SSL certificate, right?
3. His company deals with DHL to process the shipping, how can this be done? I guess it would be something like a form sent to DHL with the order details, am I right?
The company who designed his website made the purchases through 2checkout, so I don't know if I have to do the same when using webshop plus!
Thanks.
Navaldesign
Post by Navaldesign » Sun Dec 11, 2011 8:57 am
1. No, Webshop Plus does NOT inlude a Credit Card payent system, this is only for demonstration purposes.
2. yes, you would need an SSL Certificate plus a LOT more cecurity measures, to comply with the Credit Card Industry security Standards
3. You need to use a Ajax based script to send HTTP or XML requests to the DHL server with shipping info (that is, destination zip, weight and/or dimensions, desired shipping method (DHL has more than one) and receive back the shipping cost answer to include in the Orde amount.
Plus, you should consider that client most probably will need product and stock management directly online (not through WWB)
None of the above is included in Webshop Plus as it is intended for people that build their own shop and therefore they are able to manage products through WWB themselves.
You would need a Professional Cart for this, database driven and probably customized to a certain extend.
supersonictt
Post by supersonictt » Sun Dec 11, 2011 11:47 am
Navaldesign,
Thanks a lot for making things clear.
Concerning 1 and 2:
Someone can buy the product and pay using paypal as a guest (to use the credit card), so no SSL needed on the company side, right?
As i mentioned in the previous post, the company used to use 2checkout to process the order, i think it's kinda same as paypal, isn't it?
Thanks a lot.
Navaldesign
Post by Navaldesign » Sun Dec 11, 2011 11:57 am
Yes, it is similar. PayPal and 2checkout are actually payment gateways so they will accept creditcards on THEIR secure site, so no Credit Cards details are kept on your customer's website. No SSL is required, however, customers feel more comfortable giving their personal details (email address, name, address, tel number etc) on a secure (SSL) site
Navaldesign
Post by Navaldesign » Wed Dec 28, 2011 1:10 pm
Webshop v. 3.0 is now available as RC (Release candidate)
For details, viewtopic.php?f=39&t=44305
supersonictt
Post by supersonictt » Wed Dec 28, 2011 9:22 pm
Thanks a lot for this new version, I will try it very soon and report back.
Navaldesign
Post by Navaldesign » Wed Jan 11, 2012 2:38 pm
Im' sorry but it requires at least WB7 to open. f you look at the very start of the thread, you will see:
We have created a modified version of the WB5 Webshop. The modified Webshop allows you to manage all aspects of your cart without need to change a single line of code, as ALL possible changes are made through an Administration Interface.[/color=#000080][color] However it requires WB7 to open.
Now we ar in WWB and the last Webshop Cversion, v.3.0, requires WB8 to open.
Navaldesign
Post by Navaldesign » Wed Jan 11, 2012 6:46 pm
But, why should you get a license for WB7 ??? It is not even abailable....
Get a WWB8 license.
supersonictt
Post by supersonictt » Fri Apr 13, 2012 5:19 pm
@NavelDesign
The effort you put in this webshop is amazing! I really appreciate the effort :)
As I can see, version 3 is still RC, any news about the stable release?
One last thing, I TOTALLY agree with you about CC payment method (needs SSL and other security measures), but what if a client asked for that, would it be possible? Is it hard to implement this (not you to do that, but me)?
Thanks a lot.
