Auto responder in form: include form data in message
Issues related to forms.
kenderuiter
Post by kenderuiter » Fri Apr 10, 2020 3:13 pm
I am still trying to create a simple "webshop page" using a form.
I have started using the form on the WWB 'Form conditions page' called "simple cart".
When I use the auto responder option in this form with the "Include form data in message" option, the email is filled with all 'entry fields' which are in the form.
Do I have any influence on that?
Because I would rather have the email only contain the entries that have been changed on the page
Re: Auto responder in form: include form data in message
Post by Pablo » Fri Apr 10, 2020 3:17 pm
You can customize the message with variables.
See this related FAQ:
http://www.wysiwygwebbuilder.com/forum/ ... 10&t=64476
kenderuiter
Post by kenderuiter » Fri Apr 10, 2020 3:42 pm
Thank you Pablo.
So, just to make sure:
There is is no possibility to tell the form it should send only the fields that have been changed in the form?
Post by Pablo » Fri Apr 10, 2020 4:03 pm
No, there is no way for the form to know that.
GrahamW
Post by GrahamW » Sat Apr 11, 2020 12:33 am
you can also give my html-email a try
https://shop.grahamscomputers.net/websh ... ail-7.html
There is a demo there and you can set any valid html in the message/autoresponders area that matches your form fields
Graham
