File Upload (Multiple files)
Issues related to forms.
Patrik iden
Post by Patrik iden » Mon Jun 10, 2019 8:38 am
Hello, i have set a file upload field to Accept multiple files, but only one file is in the email and in database.
Using the file upload field in a form.
Re: File Upload (Multiple files)
Post by Pablo » Mon Jun 10, 2019 8:55 am
Did you use brackets in the field name?
https://www.php.net/manual/en/features. ... ltiple.php
Patrik iden
Post by Patrik iden » Mon Jun 10, 2019 9:10 am
I'v tested that now, but if i do that then i get no images att all in email and database.
Post by Pablo » Mon Jun 10, 2019 10:03 am
What exactly did you try?
Patrik iden
Post by Patrik iden » Mon Jun 10, 2019 10:34 am
In the file upload field settings i did this:
Accept multiple files = check
Name = indexFileUpload1[ ]
or
Post by Pablo » Mon Jun 10, 2019 10:54 am
And what is the error?
Patrik iden
Post by Patrik iden » Mon Jun 10, 2019 11:12 am
No images are in the email or in the database or in a folder on server.
I have set the folder name for this.
If i set the name whitout the [] brackets i get only one image.
And whit [] brackets i get no images.
Post by Pablo » Mon Jun 10, 2019 11:56 am
I'm sorry, then I guess this is not possible.
Patrik iden
Post by Patrik iden » Mon Jun 10, 2019 12:02 pm
Ok,then why the function Accept multiple files?
Post by Pablo » Mon Jun 10, 2019 12:25 pm
This is a standard HTML option, it i is provided so you can implement your own script.
Patrik iden
Post by Patrik iden » Mon Jun 10, 2019 12:26 pm
ok, thanks.
WWBman
Post by WWBman » Mon Jun 10, 2019 7:47 pm
FWIW:
If you haven't already tried it, you can have more than one File Upload object on a form.
E.g. if you think a max of 6 files could be uploaded then just put 6 File Uploads on the form.
Only the files entered will be uploaded.
GrahamW
Post by GrahamW » Sun Jun 23, 2019 5:58 am
maybe this extension could be usefull to you.
https://shop.grahamscomputers.net/websh ... nts-9.html
It will work with the WB built in PHP script as well as my HTML Email script
Graham
