Bookmark doesn't align perfectly from top of each section when clicked.
GNP
Post by GNP » Sat Dec 28, 2019 7:04 pm
Hello,
I've downloaded the Northern Lights template.
http://www.wysiwygwebbuilder.com/suppor ... ights.html
The problem is, whenever I click on the arrows of the carousel, the "bookmark" somehow shifts the height of the that section. It's hard to explain, so please check it on the link above. When you click on the arrow of the carousel, the page somehow shifts downwards alittle.
How do I get rid of that "shift", and just simply have the carousel maintain its position when I click on its arrows?
In fact, it seems that for every bookmark that links to every section of the page, it seems like it doesn't align properly from the absolute top of each section. It seems "offset" quite a few pixels downwards????
Thank you.
Re: Bookmark doesn't align perfectly from top of each section when clicked.
Post by Pablo » Sat Dec 28, 2019 9:13 pm
The 'offset' option in the bookmark properties specifies how much the page will scroll.
Note that the 'northernlights' template has a fixed header, so there will always be a 80 pixels offset.
So, if you set the offset to 80 then the bookmark will scroll to the top without being covered by the header.
GNP
Post by GNP » Sun Dec 29, 2019 7:32 am
Okay, got it. It works now. thank you so much!
