Icon on panel menu
Garrytuck
Icon on panel menu
Post by Garrytuck » Fri Sep 13, 2019 11:47 am
Hi
I have a project using a panel menu on a master page with a content placeholder.
The problem is when you load the site the panel menu icon appears on the index page (Bars) but when you load the Gallery page it only shows a placeholder.
Would you have any idea why
Garry
http://garrytuck.com.gridhosted.co.uk/thefruitbowl/
Re: Icon on panel menu
Post by Pablo » Fri Sep 13, 2019 11:48 am
Where on the page do I need to look?
And what are your exact settings?
Garrytuck
Post by Garrytuck » Fri Sep 13, 2019 11:57 am
It is the menu in the top right of the index page which has the bars icon showing, if you open the menu and select "Gallery" when the Gallery page loads you will see there is not a Bars icon on the menu just a square placeholder
Post by Pablo » Fri Sep 13, 2019 3:00 pm
I think the problem is related to a missing font awesome references, because the menu items are configured to use SVG. However, this does not apply to the trigger button.
To solve this add a (hidden) font awesome icon to the page .
Garrytuck
Post by Garrytuck » Fri Sep 13, 2019 3:36 pm
Yes that worked, thanks Pablo :D
