Why do my images get different names when I publish?
Post by Pablo » Wed Sep 07, 2011 6:42 am
When you apply effects (rotation, shadow, reflection, resample etc) or add a frame to an image then WYSIWYG Web Builder will create a new version of the image to prevent the original file from being overwritten.
You can specify the prefix of the generated file name in Menu->Tools->Options->Publish
Also in the Object Manager you can view and edit the automatically generated names through the context menu: Right click the object in the Object manager and select 'Allocated filenames'
Related tutorial:
http://wysiwygwebbuilder.com/introduction.html
