Highslide HTML-Extension
Eddy
Post by Eddy » Mon Mar 16, 2009 7:32 pm
I did clean up your topic etc ,please insert the download link always in the first post you make,thats easyer to change if you have made a update.
Pleasy write also the conditions/copyrights in your post and in a text or pdf file in the download,than people know what todo if they use your extension.
Thanks. :wink:
infos
IE :(
Post by infos » Fri Jul 10, 2009 12:16 pm
Hi-
it's a cool extension Highslide HTML Link... but does not work in IE 8 :(
thank you , anyway for your work
Post by zinc » Fri Jul 10, 2009 6:01 pm
Very nice! Thank you.
Sadly as infos has mentioned it does not work on IE 8. It seems to want to start but then it makes it look like it is a normal page. Are you aware of this.
infos
it does work even in IE 8, here is my tip :)
Post by infos » Sat Jul 11, 2009 11:42 am
I managed to view "inline the highslide HTML" in IE 8, there is my tip:
instead of
"<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">"
in the beginning of page, you have to have this:
"<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.1//EN" "xhtml11.dtd"><html>"
Most important is to have "xhtml11.dtd" and NOT "html 4.01 transitional"
For me, now it's working just right in IE 8, I mean, this particular extension "highslide HTML" for wysiwyg web builder program.
cheers,
Post by BaconFries » Sat Jul 11, 2009 11:47 am
You can already do this very simply in WB6 open the page properties look for Document Type: change to XHTML 1.0 Transitional....and it solves a lot of issues...
Post by zinc » Sat Jul 11, 2009 11:48 am
Cool! Thanks for that!
However I get the Goldbar in IE blocking it initially.
infos
Post by infos » Sat Jul 11, 2009 11:51 am
BaconFries wrote:You can already do this very simply in WB6 open the page properties look for Document Type: change to XHTML 1.0 Transitional....and it solves a lot of issues...
yes, is what i mean :)
Post by zinc » Sat Jul 11, 2009 12:27 pm
Yes the problem is I am getting IE's Block bar. But I guess it is because it is running locally and not published. Right?
Post by BaconFries » Sat Jul 11, 2009 12:39 pm
You got it in one sneil previewing locally causes IE to get all excited over nothing really lol...it just the fact that the javascript is running in background I believe and IE being IE see it as a threat...
Post by zinc » Sat Jul 11, 2009 12:45 pm
BaconFries wrote:You got it in one sneil previewing locally causes IE to get all excited over nothing really lol...it just the fact that the javascript is running in background I believe and IE being IE see it as a threat...
Thanks for that BF. This is a problem when FF is your choice browser. I get excited about a site I do and then I am reminded not to forget IE!!! :evil:
Post by zinc » Sat Jul 11, 2009 12:53 pm
The ESC key does not seem to work for me. Also It would be good if you could get it to work with images as well.
Post by BaconFries » Sat Jul 11, 2009 12:54 pm
That to me or extension author.....
Post by zinc » Sat Jul 11, 2009 1:02 pm
BaconFries wrote:That to me or extension author.....
Sorry Ext. Dev. I have emailed you.
