Snazzy Maps (FREE)
traco
Re: Snazzy Maps (FREE)
Post by traco »
Thanks for the quick reply.
2. The gaps will only appear if you don't fill out the extension fields correctly - look at page three of the help file and you will see that each line is an individual field. If you don't fill them in you get a blank line also.
I did This.
Adendum
Post by Adendum »
Not sure what is happening here.
[a] try removing the apostrophe in the location name and see if that does anything.
if not I'd need to see your project to be able to dig deeper.
Death to Internet Explorer!
Hi Paul not hijacking this butvtry bthe following
Ok to over come this we need to do add this ’ in place of the '
For example:
Mrs. Lewis ' s car is nice.
becomes below but will render/display correctly when published/previewed
Mrs. Lewis’s car is nice.
traco
Post by traco »
I Tried..
what do you need?
wbs file or generated HTML?
Adendum
Post by Adendum »
1. Open your project and SAVE AS a new name.
2. Delete all the pages except for the Snazzy Maps page.
3. Go to assets and delete all the unwanted files.
That will leave you with a nice and small .wbs with the new name and a matching folder that contains only the images used in that page.
4. Zip up the .wbs and folder
5. Email me from this page and I will email you back so we both have email addresses.
6. When you get my email response you can send the zip file.
Adendum
Post by Adendum »
I am going to need someone else's thoughts on this one because I am now officially confused.
Traco has sent me his project. Nice and simple, one address in the extension. When I preview it I get the same results as he does - extra lines after the location heading.
When I copy the extension from HIS project into MY project and then preview it is perfect - no line spacing.
When I copy MY extension from the demo project and preview in HIS project I get the two extra lines.
So clearly there is something different in the settings of his project compared to mine. It can't be different settings in WWB otherwise I would be getting good and bad results. And here's why I am confused.......I have replicated all the page settings used in my demo in his project page but it makes no difference.
So what else could cause this kind of discrepancy?
Oh and for the record if I create a new project and manually enter all the same data as Traco's and preview I see everything as I would expect. :shock: :shock: :shock:
With permission of course (traco) if you want to send it to me Paul and I will take a look...
traco
Post by traco »
No problem for me if it can 'help solve the issue.. Thanks
Adendum
Post by Adendum »
@Bacon,
Glad to have you on board fella. I'm lost for a cause let alone a solution.
Ok not hijacking here... One issue or explanation to why the map may not display is this it uses javascript, now if you do not have javascript enabled in your browser then it will fail to open as it is ment. If you cannot preview in WB then you may ticked the checkbox Disable IE security warning during preview. You will find this setting in Tools->Options->Publish&Preview->Preview simply uncheck this and try again. If it still doesnt display then you will need to enable javascript to run on your PC, if you are not using IE, then you will again need to allow javascript to run in what ever browser you use, note this is nothing to do with the extension in anyway it is a PC or browser setting required to run the script...
Adendum
Post by Adendum »
Wow! :shock: :shock: :shock:
traco
Re: Snazzy Maps (FREE) SOLVED
Post by traco »
@Adendum and @ Bacon
After dozens of attempts I solved it this way:
I created a new project
I imported the old project into the new project (import page from a other project)without the extension I added snazzy and put all settings
The problem is' solved ..! I'm confused but happy .. thanks for your support ... :D :D
Ps
The same page in old project stil has the problem :roll:
supersonictt
Post by supersonictt »
Adendum,
Thanks a lot for this extension! Really great :)
I have a question please: in your demo page, the info window appears different than the extension generates:
1. There is a space from the top of the window to the heading text, and a big space between the heading text and the address.
2. The heading text in your demo has a different color. I know it is all about styling, but could you please provide a sample project just like the one in your demo site? Or maybe some hints?
Thank you :)
p.s.: I included a link of an image of how the info window is generated by the extension.
---------EDIT---------
Ok I got it :)
Thanks a lot :)
Adendum
Post by Adendum »
lol, glad I could 'help'.
supersonictt
Hehe :D
Well, I have a suggestion, and I believe it will be very useful:
In the Map Options -> Heading Size, if this option can be editable it will give the flexibility for users to style the header the way they want. In Style Manager, I had to change the font, color, size and other stuff to make it appear the way I want, AND I had to make a copy of H4 (as an example) to save it as a backup so I don't lose its original values. So, if this option is editable, I can put H4_map, and in the Style manager I can make this H4_map and style it the way I want.
Hope I made sense in my suggestion :)
Thanks Adendum ;)
maxam
Post by maxam »
sorry for the dum question but how can I download the extention?
Adendum
Post by Adendum »
Same as any other extension - in WWB Tools>Extension Manager and install from there
Sergio Morais
Post by Sergio Morais »
Snazzy Maps extension has stopped working.
Most of my published sites return the following error when consulting the page containing the map:
"This page was unable to display a Google Maps element. The provided Google API key is invalid or this site is not authorised to use it. Error Code: InvalidKeyOrUnathorisedURLMapError"
API code maybe?
Apparently mine is still valid as oddly enough one site's map still works.
Referrers?
Added the domain names (and its derivatives) to Google Developers Console. To no avail...
WWB version?
Also been checked. It's not that.
What could this be?
Anyone come across this yet?
Thanks.
aml02873
Post by aml02873 »
Had the same problem a while ago. Applied for a new API key and it worked again.
Sergio Morais
Thanks.
I will do the same.
You obviously had to go through all your sites, fill in the new API and republish them, right?
Regards.
aml02873
Post by aml02873 »
Yep
Sergio Morais
Applied for a new browser API, copied and republished, but still, no cigar...
Added the domain to the referrer list; nothing...
Anything else you can think of?
I forget, is SM supposed to show you the map when in preview mode?
Thanks.
I am sure Adendum wont mind me relying to you regarding previewing in WB on the other issue I cant help. Please read the following
BaconFries wrote:Ok not hijacking here... One issue or explanation to why the map may not display is this it uses javascript, now if you do not have javascript enabled in your browser then it will fail to open as it is ment. If you cannot preview in WB then you may ticked the checkbox Disable IE security warning during preview. You will find this setting in Tools->Options->Publish&Preview->Preview simply uncheck this and try again. If it still doesnt display then you will need to enable javascript to run on your PC, if you are not using IE, then you will again need to allow javascript to run in what ever browser you use, note this is nothing to do with the extension in anyway it is a PC or browser setting required to run the script...
Sergio Morais
Thanks for your answers.
Regarding the latest, I have tried these pages on different PC's and browsers. Same result.
All was working perfectly until a short while ago. In my humble opinion, it seems that Google Map/Console changes have something to do with this; IDK
Sergio Morais
Found a temporary workaround.
And I mean temporary!
Delete the API field in the SM extension and we're back in business! (with a blank API field)
Obviously, this will not last forever...
The extension is no longer available from the extension manager as it has been removed and is no longer supported by the developer sorry.
@lifeisliberty Please read the following:
https://www.wysiwygwebbuilder.com/forum ... 53#p368253
And how you can use a*fix that will allow you to open a project if a extension is missing.
https://www.wysiwygwebbuilder.com/forum ... 10&t=67924
