What are the signs when running out of memory?
hobo
Post by hobo » Fri Apr 13, 2018 11:11 pm
Someone ask about page limit, the answer was that it is only depending on memory.
What will hapen if you do?
I had a page with about 100 pictures and everytime this page would generate the html
the screen goes black and sits there for a while before it continues.
Are those the symptoms when running short on memory?
Thanks for any tips.
Re: What are the signs when running out of memory?
Post by Pablo » Sat Apr 14, 2018 6:54 am
Yes, your system will become slow and unresponsive itf it running out of memory.
I think 100 pictures on a single page is way too much. This will cause more than 100 http requests to the server when users are visiting your page!
fochardo
Post by fochardo » Sat Apr 14, 2018 7:59 am
And if the page containt 100 or more picture but in different slideslow that run in mode lightbox. These images i thing that only uses memory when load? Is correct. Maybe would be a solution.
