jor_accordionManipulation 2.0
jor_accordionManipulation update 2 can be used to manipulate the WB jQuery Accordion in 4 ways:
01. single style a WB jQuery Accordion easy with any of the 24 default themes
02. customize all properties
03. set individual content height for each panel
04. create external control
jor_accordionManipulation update 2 is a rewrite of jor_accordionManipulation ... now the ultimate single style jQuery Accordion manipulator!:)
NEW**! in update 2
- direct select any of the 24 default themes by a single property
- customize all properties, - even switch back and forth between default themes maintaining customized settings
- set individual content height for each panel
- option corner radius
- option header text align
- option external control trace mouse behavior
- WB version is now set once global ...
DEMO jor_accordionManipualtion: visit jorextensions.com
DOWNLOAD: jor_accordionManipulation
Builder: jordan (6j6)
Code: jordan (6j6)
EB version: 4.1.0
WB version: 8+
jQuery lib: 1.7.2/1.9.1/1.11.1
jQuery UI: 1.8.2/1.10.0
W3C valid: Html, Xhtml
HISTORY:
-#-#-#- update 1: -#-#-#- 07/jul/13
01. removed: show/hide/iframe manipulation removed
02. changed: content is stored in jor_ui_themes folder
03. fix: compatible WB8/9 (UI)
-#-#-#- update 2: -#-#-#- 19/oct/14
01. new: select any of the 24 default themes by a single property
02. new: set individual content height for each panel
03. new: option corner radius
04. new: option header text align
05. new: option external control trace mouse behavior
06. enhanced: option disable theme instance
07. enhanced: WB version is now set once global
08. enhanced: added color mode properties (not used/used/transparent)
09. enhanced: icon width/height is now set automatic
NEW**! in update 2
Code: jordan (6j6)
EB version: 4.1.0
WB version: 8+
HISTORY:
Re: jor_accordionManipulation___*NEW*
Thx Jordan, you're a very great developer !
[url]http://Peyronnin.fr[/url]
woomp woomp … very nice words FredericP thank you very much!
very glad you like . .
Re: jor_accordionManipulation_update 1
jor_accordionManipulation update 1
jor_accordionManipulation update 1 is a rewrite of jor_accordionManipulation ...
01. removed show/hide/iframe manipulation removed
for full update history, demo and download see top post
Re: jor_accordionManipulation_update 2
see a cool new demo for jor_accordionManipulation at - visit jorextensions.com
Re: jor_accordionManipulation_update 2 **NEW**
. . appreciated:)naftalina wrote:Thanks
Re: jor_accordionManipulation 2.0
hello jmdediosperez,
I don't understand the question ?
youtube and the accordion are two objects
if you need a youtube player inside an accordion place the youtube player in the accordion ?
hi jmdediosperez,
I still don't understand the question, please be more specific
maybe you can point to an example of what you want to do ?
- protectourlands
Jordan I think he is asking for a video tutorial on how to use this extension that is accessible through Youtube.
jmdediosperez, the extension is pretty self explanatory and comes with a pdf guide when you download it.
If there is something specific you are looking for help on, just ask it here. It is a fantastic extension for the WB accordion tool.
ah, ok, if that's the case then yes, please look at the jor_accordionManipulation_easystart project in the downloadprotectourlands wrote:Jordan I think he is asking for a video tutorial on how to use this extension that is accessible through Youtube.
also the jor_accordionManipulation.pdf may help
and if you have a specific question indeed just shout out here jmdediosperez, i'll be glad to assist:)
@ protectourlands - TNX much for the translati-sh direction:)!
Hi Jordan.
Could you tell me, is this extension responsive? I have jQueryAccirdion1 in my default design and jQueryAccordion2 in my 320px breakpoint design but it doesn't work for me.
i
i
hello Idler,
yes, jor_accordionManipulation can be used RWD, it does not do anything to breakpoint setup
how are you using jor_accordionManipulation, what does not work, do you have a live demo ?
Hi Jordan
Thank you for your reply. I have an issue with jQueryAccordion which I thought might have been caused by your extension. However, I don't believe that it is your extension but something else. The site is http://www.mervspotfringe.com.
BTW Thank you for creating the extension. Hugely useful.
i
i
Hi Jordan
Further to my earlier message, I would be grateful if you would take a look at the site http://www.mervspotfringe.com. I have now realised that the panel heights are not working the same in jQueryAccordion1 as they were before I added jQueryAccordion2. Prior to adding jQueryAccordion2 there were no scroll bars. Any idea as to why this is happening?
i
i
hi Idler,
all I can see on that page is that both accordions 1+2 are visible after the breakpoint ?
set jQuery Accordion1 to state hidden after the breakpoint
but the theming and height you have set up in jor_accordionManipulation both work correct
so I don't understand what the question is in relation to jor_accordionManipulation
jor_accordionManipulation seems to work correct
+ TNX great you like
Hi Jordan
I am a newbie to RWD so you won't be surprised to hear that the error was all mine. All is now well. (I hadn't checked 'include visibility'.)
Thanks again for taking the time to reply. Very decent of you.
i
i
Hi Jordan
I am having a problem with text in this extension. Please see image at: http://www.mervspotfringe.com/problem. This seems to be happening with Macs though Bacon Fries has just posted that he had the same problem on I Explorer (though don't know if he is using a Mac or not). Can you through any light on what the problem might be?
Many thanks
I
Many thanks
I
Hello idler,
I can see the same problem occurring on your site as BaconFries pointed out (on any of the major browsers - pc)
your site for some reason takes a very long time to start loading ?
I think nothing is wrong with the page/code itself but the timing of different scripts get bogged by the server
(wait a day, maybe it resolves?) - check with your provider!
Hi Jordan
Many thanks for taking the time to reply. I will talk to my host server and see what he says.
I
I
OK, hope it resolves for you soon Idler, keep me posted!Idler wrote:Hi Jordan
I
Hi Jordan,
I have been using your extension and have to say it is really great!
I do have a question that I hope maybe you could help me with.
I would like to be able to create several links from a css menu on another html page that takes the user to a page with an accordion and automatically opens up to the appropriate section of the accordion based on the link that was clicked.
I see that your extension does have an "external control" ability, but I can't figure out if I could use it for the above mentioned or not. Perhaps you have a work-around that I could try?
Thanks,
Mir
Thanks,
Mir
hello mermaid,
if you want to transfer data from one page to another you need to script it
use of cookies or parameter on the url or ... etc
here is a quick sample on the url - LINK REMOVE
I can not help with custom coding so you have to extend and/or implement to your own needs
this is just a "something along the lines of":)
hope it helps!
hope it helps!
Hello Jordan,
WOW - thank you so much!!!
The example you sent me was just what I needed to get this working.
Just can't thank you enough for the fast support. You are the best.
Mermaid
Mermaid
