PrettySociable Extension Version 1.0.2
prettySociable is a jQuery plugin that tries to make sharing fun while being easy to use.
The original script and copyright stuff can be found here http://www.no-margin-for-errors.com/pro ... e-sharing/
DEMO
Have a look at the demo here: http://www.no-margin-for-errors.com/pro ... e-sharing/
NOTES
1. A sample project is included in the zip file, open it and see how things should be done. If I find another easier way to do it I will update the extension. And, if anyone knows a better way please post it here.
2. I replaced "reddit" with "google+" and changed the sharing icons so the are all within the same theme.
UPDATES
Before mentioning the update, a VERY BIG THANK YOU to the TRUE TEACHER [rz] for his help in implementing the "Before </body>" script code
Now there is no need to add the any script codes, only the one described in the sample project.
Download link is now updated.
v1.0.2: Updated the jquery librery to 1.7.2 to make sure there are no conflicts with the built-in jquery.
DOWNLOAD
http://www.mediafire.com/?vxzb9utlxbcza9q
INSTRUCTIONS
1. Install the extension.
2. Drag it anywhere you want and modify its settings.
NOTE: The sample project contains the detailed instruction, so read it and see how it works.
Enjoy
PrettySociable Extension - January 27, 2013
Last edited by supersonictt on Sun Jan 27, 2013 10:23 am, edited 3 times in total.
Re: PrettySociable Extension - 01/09/2012
did you see the included project?
upload your project please to see what's wrong.
- madebyibloo
Hi supersonictt! great extension thanks!
just a little question.......In Extension Builder, Can you please use the provided jQuery option inside of EB instead of using a separate jQuery ? it conflicts with other jQuery versions.
If you don't understand me, I can help you with the option.
Cheers,
Scott
Cheers,
Scott
Cheers,
Scott
Scott
Hello SUB
Thanks for your kind words
Yes, I will use the built in jquery library, it will be ready by tomorrow
- madebyibloo
supersonictt wrote:Hello SUB
Thanks Sonic!
Cheers,
Scott
Scott
- madebyibloo
Hi sonic, any news on this yet?
Cheers,
Scott
Cheers,
Scott
Cheers,
Scott
Scott
SUB,SUB wrote:Hi sonic, any news on this yet?
Cheers,
Scott
Check the first post, I updated it
Enjoy
- madebyibloo
Re: PrettySociable Extension - January 27, 2013
Thanks sonic! superb!
Cheers,
Scott
Cheers,
Scott
Cheers,
Scott
Scott
