***SOLVED*** Inserting HTML code banner
Joseph Lee
Post by Joseph Lee » Sun Apr 19, 2020 10:59 pm
I would like to insert HTML code for an Ad banner, but nothing shows up on the page after publishing it.
Using the HTML Properties window.
  <a href="https://asiafriendfinder.com/go/g928372-pct" target="_blank"><img src="https://secureimage.securedataimages.com/banners/ffz//26456/26456_300x250c.gif" width="300" height="250" border="0" />
Thank you...
JL
Re: Inserting HTML code banner
Post by crispy68 » Sun Apr 19, 2020 11:07 pm
Your code is missing the ending link tag. You need to add a </a> at the end. Works for me when I preview.
Joseph Lee
Post by Joseph Lee » Sun Apr 19, 2020 11:23 pm
<a href="https://asiafriendfinder.com/go/g928372-pct" target="_blank"><img src="https://secureimage.securedataimages.com/banners/ffz//26456/26456_300x250c.gif" width="300" height="250" border="0" /></a>
Thank you for responding.
Still not doing it for me...
Post by crispy68 » Sun Apr 19, 2020 11:27 pm
Then I would say there is something else on your page causing the issue as it works for me when I preview. Do you have a link to the page?
Joseph Lee
Post by Joseph Lee » Mon Apr 20, 2020 1:04 am
Yes, but please be aware there is some slight nudity.
*** link removed due to its nature of content porn***
Thank you for helping!
Reason: Link removed due to sites content which is porn which may offend users
Joseph Lee
Post by Joseph Lee » Mon Apr 20, 2020 4:55 am
Sorry about that crispy68.
I discovered the issue, Firefox had a plugin that blocked it, once disabled, was able to see the ad fine. It also worked in all other browsers.
Thank you for the help, and sorry for breaking the rules!
