Trying to work out the best shopping cart for my site, I currently using stiva script by jabbers and it behaves reasonably well, the reason I went for this script was it bedded into my site and didn't look like something was just tacked on. I wanna to move to another cart which offers more functions such as opencart, prestacart or anything else.
Is there a way to add these carts to an existing site? ideally I want to add it in between my existing header and footer?
Embed Shopping Cart into Website
Re: Embed Shopping Cart into Website
You can add third party code with the HTML object.
https://www.wysiwygwebbuilder.com/add_html.html
Thanks Pablo, not sure that will help me. I've created a shop front using prestashop, there is no way I can see where I can grab the html code.
However what appears to work is inserting a inline frame within a grid, it's also responsive. Surely that can't be it....must have a downside?
Thanks in advance
Thanks in advance
Correct, if you do not have knowledge about HTML then you can also use the inline frame.
You may find the following url helpful regarding installation.
http://doc.prestashop.com/m/mobile.action#dashboard
