I need a working Site Statistics and Visit Counter
mindentezzel
Post by mindentezzel »
Hy Pros,
I am a hobby web creator, I build almost only my own website. My earlier free web statistics is out of order, because Gostats is out of the business. I need a Site Statistics and Visit Counter. (Google is not able to show the ip addresses, so NO google pls.)
I use wb1521. I have bought the CRUDE MySQL and the Site Statistics and Visit Counter extensions, but I am not able to create a MySQL database and the other things I need to build a counter to my own website.
Would you pls help me, or rather to give me a basic and working version of Site Statistics and Visit Counter extensions that is able
  • to count and
  • to show the ip address
  • and other normal statistcs of my visitors.
I also need file.php that creates a new MySQL database.
I won't you to do it for free, I will pay for your work.
Thanks.
T.
WWBman
Re: I need a working Site Statistics and Visit Counter
Post by WWBman »
www.statcounter.com is pretty good and has a free option.
mindentezzel
Thank you, I haven't found this one before. I'll give a try, but I think, the self made version will be cheaper :)
So, I still need help.
Did you try to to create the database based on the information in the PDF?
mindentezzel
Dear Pablo,
I have read everything, but I gave up at the first question namely "primary key", this must be a very simple thing, unfortunately I don't know what it is.
Unfortunately, there is no easy way for me to explain MySQL and PHPAdmin.
But there are many tutorials available online.
https://www.google.com/search?q=introdu ... l+phpadmin
When using Site Statistics and Visit Counter the primary key is not really relevant because it will be created automatically when you import the script into PHP admin.
mindentezzel
Thank you for your kind help
