.htaccess file
laros
.htaccess file
Post by laros » Sun Jun 23, 2019 5:33 pm
Hi.
I have a website ***
I would need a code to remove file extension (php) that is working properly and does not affect other php code on the page.
Can somebody help me?
Re: .htaccess file
Post by BaconFries » Sun Jun 23, 2019 5:49 pm
This is something that your host can assist with, you should contact them for help as it really is a server configuration and not related to the use of the software. Note for this to work you will need to ensure your host/server supports Apache and only they can help to say if it does.
