ToolTip - EXIF - Image
digizar
Post by digizar » Sat Mar 16, 2019 7:25 pm
https://blumenfotos.org/farben/blau/blau1.html
Hover shows the type of camera (out of the EXIF), here Minolta DSC.
Is there a way, to generally / globally remove the EXIF-Information of an image?
May be replace that with a global setting 'Klick for full screen'?
Thx, to ziens. :-)
Ask question only if there is no answer yet.
Re: ToolTip - EXIF - Image
Post by BaconFries » Sat Mar 16, 2019 8:32 pm
Not within the program you will need to do this externally and then bring the image back in. Once you have done this you cpuld use the alt tag for giving a short description of the images(s)
See the following:
https://www.google.com/search?q=remove+ ... e&ie=UTF-8
digizar
Post by digizar » Sun Mar 17, 2019 12:44 am
See the following:
Sorry, wrong way, in case the EXIF is required later.
Post by zinc » Tue Mar 19, 2019 5:30 pm
For that you need something like this...
https://github.com/exif-js/exif-js
digizar
Post by digizar » Wed Mar 20, 2019 12:34 pm
Thanks for info, I will consider it carefully.
But that is the easiest part of the game.
So far I can go and remove all the exifs manually.
The exif information at that instant seems to be completely unnecessary.
Sorry that I still don't yet have too much knowledge about the details of webdesign. There was no need for these details.
That's why I'm using such tools als WWWBuilder or OpenElement, WebEasy, Kompozer, ... https://hobbyseiten.org
But I might think about learning the details and to build 'some extensions', some objects, which I miss.
Question: What would be the wisest way to begin with? Some UI / API available?
Keep in mind, I'm retired and I have a comlete new aorta asc; now again I have relative plenty of time to spend. :lol:
