Comparison Slider
gregbarnes
Comparison Slider
Post by gregbarnes » Thu Nov 15, 2018 1:59 am
I'm wondering if there is a way to incorporate a "Comparison Slider" or "Before / After" slider for showing the difference between 2 images. here's what I mean. https://codyhouse.co/demo/image-compari ... index.html
Cheers for now,
Greg
Re: Comparison Slider
Post by crispy68 » Thu Nov 15, 2018 3:39 am
Did you see this?
viewtopic.php?f=42&t=79586
Post by [RZ] » Thu Nov 15, 2018 1:28 pm
gregbarnes
Post by gregbarnes » Mon Dec 23, 2019 9:03 am
I decided to give TWENTY TWENTY a go. It seems to work well but for one bug. I run my website from any browser and on the menu bar I select "Colourise B&W" and when the page displays, the Twenty-Twenty box is blank. I have 9 image comparisons (Colour and B&W) and selecting any of the 9 still have a blank box (no images). Here's the kicker - I select the HOME menu and return to the home page, then click the COLOURISE B&W menu and the Twenty-Twenty images now appear. I have the 20/20 before and after images in their own separate layer containers which I just turn on or off depending on the number button selected. Is there a setting in the 20/20 properties OR the Layer properties which will be able to display the images when the page is first selected from the main menu. Very strange and I'd be grateful for any solution. This is my website https://www.isacimages.com.au Cheers Greg.
Cheers for now,
Greg
Siegbert
Post by Siegbert » Mon Dec 23, 2019 4:10 pm
Hallo Greg,
you have many pictures of your homepage. Did you set all the pictures with the board tools from WYSIWYG or did you use a special program or code?
What size is each picture. I would like to use WYSIWYG Builder in the future to also include picture galleries.
Siegbert
gregbarnes
Post by gregbarnes » Tue Dec 24, 2019 8:09 am
Hi Siegbert,
I just use the "Image" tool to show my images and place it anywhere on the page. They range in size from 800px to 1024px.
For the galleries I use the "Photo Gallery" tool, which can have lots of photos in. I Highly recommend WYSIWYG for your website.
Cheers for now,
Greg
Siegbert
Post by Siegbert » Tue Dec 24, 2019 8:24 am
Hi Greg,
thank you for the information.
As soon as I have a little more time I will create my homepage with WYSIWYG.
Siegbert
Williams
Post by Williams » Fri Dec 27, 2019 1:54 pm
For me, Twinty Twinty extension which posted by Crispy doesn't work properly with breakpoints. it only works if the project contains only default view.
Am i right!!
Post by crispy68 » Fri Dec 27, 2019 8:48 pm
You are correct! It doesnt work in breakpoints or layout grid for me.
Contact me at ron@wizbangwebdesign.com and I may have a solution for you.
gregbarnes
Post by gregbarnes » Thu Apr 09, 2020 4:17 am
Many thanks to Crispy68 (Ron) from www.wizbangwebdesign.com. He has issued an update to the Twenty Twenty slider extension and it works perfectly on my website in the Colourisation page at www.isacimages.com.au. It's called WBWD-Twenty-Twenty1.2
Many thanks Ron :lol:
Cheers for now,
Greg
jerryco
Post by jerryco » Thu Apr 09, 2020 10:30 am
That looks mighty impressive! Gooo tech!
gregbarnes
Post by gregbarnes » Fri Apr 10, 2020 12:52 am
Thanks for the comment jerryco! Kudos to Crispy68 for his great After Sales Service and for getting the script sorted so that it works seamlessly.
Cheers for now,
Greg
ColinM
Post by ColinM » Fri Apr 10, 2020 2:22 am
Hi Greg,
Just wanted to extended a greeting from a fellow Sandgroper - I'm down in Mount Barker! 8)
Yours truly
Colin M
Western Australia
My Website
gregbarnes
Post by gregbarnes » Fri Apr 10, 2020 4:15 am
Great place to be staying put mate! Happy Easter to you and your loved ones.
Cheers for now,
Greg
ColinM
Post by ColinM » Fri Apr 10, 2020 4:48 am
We agree Greg - thanks for the Easter wishes - back at ya! 8)
Yours truly
Colin M
Western Australia
My Website
