JQuery slider links to Javascript
IanRob
Post by IanRob » Fri Oct 05, 2018 10:41 am
I appreciate you cannot give advice on specialist code. However, is there any information on how to link the JQuery slider in WebBuilder to Javascript code?
My Javascript programmer does not have experience in JQuery. He is having problems linking to WebBuilders JQuery slider.
The id (Slider1) created for the JQuery slider is for the div, not the slider.
I assumed that it would be possible to connect WebBuilder's Jquery slider with Javascript code using an id of Slider1.slider.
e.g sliderx=document.getElementById("Slider1.slider");
However, that does not seem to work.
Thanks in advance for any help on this
Re: JQuery slider links to Javascript
Post by Pablo » Fri Oct 05, 2018 11:16 am
Maybe this information will be helpful?
http://www.wysiwygwebbuilder.com/using_sliders.html
IanRob
Post by IanRob » Fri Oct 05, 2018 3:11 pm
Thank you Pablo
The .bind used in the color example is depreciated in version 3 of JQuery
Can that cause problems?
Post by Pablo » Fri Oct 05, 2018 3:26 pm
You can can use 'on' instead.
IanRob
Post by IanRob » Thu Oct 11, 2018 4:55 pm
Hi Pablo
I have looked at the color JQuery slider example that you suggested
The problem is that on that example, although the min and max for the slider are set to 0 and 255, the "value" of the slider only goes from 1 to 254 at each extreme
Is that by design, or a bug?
Is there any way to get over that problem?
Post by Pablo » Thu Oct 11, 2018 5:14 pm
It seems to work as expected.
See also the documentation:
http://api.jqueryui.com/slider/
