Login dialog on local machine
alex4orly
Post by alex4orly » Sun Aug 26, 2018 7:01 am
Just installed and started using XAMPP on my Windows 8.1 machine
All works fine and I can test things before uploading to the live site, but...
If I try to access the Loging dialog by direct URL, it works fine on the website, but on my local XAMPP, it shows
This : http://www.beleuramyhome.org.au/login.jpg
I know we don't have XAMP support here, but maybe someone has an idea???
Cheers
WWBman
Re: Login dialog on local machine
Post by WWBman » Sun Aug 26, 2018 9:10 am
What url are you using?
I've just tried it and it works on my test login project using: localhost/test1/index.php
index.php being the equivalent to your login.php
WWBman
Post by WWBman » Sun Aug 26, 2018 10:53 am
Are you using a MySQL database?
Is it set up the same as the 'live' one?
I guess the error may be a PHP notice error and the PHP error level in Xampp is more severe than your host's level.
Try temporarily turning off error reporting by using:
<?php
error_reporting(0);
and see what happens.
alex4orly
Post by alex4orly » Sun Aug 26, 2018 8:41 pm
Hi WWBman,
The "Problem" started here - https://www.wysiwygwebbuilder.com/forum ... ead#unread
I asked what is the purpose of the two final code lines generated by WWB :
$username = isset($_COOKIE['username']) ? $_COOKIE['username'] : '';
$password = isset($_COOKIE['password']) ? $_COOKIE['password'] : '';
I didn't get an answer and commented those two lines out, I didn't understand what are they for.
It seems that commenting those out, doesnwt cause a problem on the live server, but XAMPP shows the error.
After un-commenting the 2 line, XAMPP works just fine
Thank you
