NOT FOUND [CFN #0005#]
Senior Paper Monitor
Post by Senior Paper Monitor » Sun May 27, 2018 3:36 pm
One of my sites (with Easily - a host on the verge of collapse) is showing ‘Not Found [CFN #0005]’ on some pages (which have been normal until this morning – example: http://www.themortgagelady.xyz/privacypolicy
I believe this is a server issue (and its Easily – so no chance of support) – anyone familiar with this one?
I have re-uploaaded the site and the affected pages with no success
Re: NOT FOUND [CFN #0005#]
Post by Pablo » Sun May 27, 2018 3:49 pm
If it suddenly stopped working then it can only be a server related issue.
I am not sure if you can solve this unless you have changed something yourself that has caused this issue.
Post by BaconFries » Sun May 27, 2018 4:31 pm
I would check your .htaccess file if you have used one for any typos etc..
Post by Senior Paper Monitor » Sun May 27, 2018 5:18 pm
Thank you Gentlemen ...
It was displaying fine a couple of days ago, but for the last two days has shown that response - other pages OK
I did nothing.
There is no htaccess used on that site
RiaanN
Post by RiaanN » Mon May 28, 2018 9:27 am
Are you using an index.php file. - Are some of the pages in the project making use of a php extension ?
Add a .htaccess file and change it to use index.php
Some hosting companies accepts URLs without index.php in them, but others need the index.php for the SEF to work.
Post by Senior Paper Monitor » Mon May 28, 2018 10:06 am
Thanks RiaanN,
There are a couple of PHP pages on the site - and I now the host is making some changes in the background (just no idea what).
I'll try that
Post by Senior Paper Monitor » Wed May 30, 2018 6:37 am
This is a more a warning about Easily as a registrar/host (see this stuff: https://uk.trustpilot.com/review/www.easily.co.uk) than looking for an answer.
My important site should move today/tomorrow to a new host (there rest will follow)
My temporary solution to the missing pages (GDPR privacy policies) was to throw them onto another site (same name just .co.uk rather than .xyz) and repoint our email/s links etc.
Worked a treat - until this morning, went to check some wording I wanted to refer and now those are showing NOT FOUND [CFN #0005#] !!!
