Pick-up and Drop-off with map script
ruel.lago22
Post by ruel.lago22 » Thu May 10, 2018 8:28 am
Good day everyone,
I am looking all over the internet on how to put Pick-up and Drop-off with a map to our website form. We are planning to start-up a pickup and delivery service website. One of the reasons why I want that feature is to minimize our time in looking for the customer's Pick-up location and their drop-off point. It's going to be allot faster if we have that so we can just use "Waze or Google Map" to find them.
I understand that WWB does not support this feature but if we add/integrate them manually, it's possible. Does anyone know how to do it? Any insights, comments or suggestions would be so much appreciated :)
It looks like this: https://prnt.sc/jg0fp2
Re: Pick-up and Drop-off with map script
Post by BaconFries » Thu May 10, 2018 1:00 pm
Google Maps allows you to input directions from point A to point B then output/display it on the map with directions below. I mention Google Maps purely because they bought 'Waze' in 2016 so you should be able to combine both.
See following example shows Direction From/To
https://www.mapdevelopers.com/distance_from_to.php
Second shows how to use 'Waze' search for location only!!
https://developers.google.com/waze/iframe/#examples
Or
https://support.google.com/maps/answer/ ... ktop&hl=en
Note this is just provided as pointers to maybe help you...
ruel.lago22
Post by ruel.lago22 » Fri May 11, 2018 8:48 am
Thank you so much :) This is where I will start.
