checkbox, radiobutton with label tag inclued
Issues related to forms.
vincen
Post by vincen » Mon Apr 23, 2018 8:24 am
Hello,
I discovered that the Form controls checkbox and radiobutton contained a LABEL tag.
Example:
<input type = "checkbox" id = "Checkbox1" name = "" value = "on" style = "position: absolute; left: 0; top: 0;"> <label for = "Checkbox1"> < / label>
This novelty seems to me very practical but unusable, because it is impossible to introduce a value inside the tag LABEL
Thank you in advance for clarification on this subject.
Vincent Blanc
Re: checkbox, radiobutton with label tag inclued
Post by Pablo » Mon Apr 23, 2018 8:40 am
The label is used to be able to modify the appearance of the checkbox, which normally would not be possible via HTML/CSS.
Enable 'Use default browser styling' if you wish to use a standard checkbox.
