convert numbers to a string and currency
jwallner
Post by jwallner » Mon Oct 02, 2017 2:28 am
I am looking for examples of how to display a number as currency in a text field. Everything I have tried does not work. This program has everything but this function.
Like this:
Price $: 1,000
I was able to display the text and the value, but can't figure out how to do the formatting to show the value of "Editbox3"(my test number field) as currency.
"Price: $" + [Editbox3].toString()
Am I missing something that is built-in? Any help would be great.
John
Re: convert numbers to a string and currency
Post by BaconFries » Mon Oct 02, 2017 3:07 am
Have you read from the following:
Conditions
Post by Pablo » Mon Oct 02, 2017 5:56 am
This is not specific to this program. You will need to implement this with JavaScript.
Just like Bacon Fries suggested you can try to use conditions..
http://www.wysiwygwebbuilder.com/suppor ... ions4.html
jwallner
Post by jwallner » Mon Oct 02, 2017 11:47 pm
Thanks for the reply. I already have the symbol and the number. The problem with the format is that it shows it as a decimal and not currency.
This is what I have now:
Price: $ 1134.00
What I would like to see is this:
Price: $ 1,334.00
How would conditions change a decimal point to a comma? Pablo, your example does not show a number large enough to example this. I totally understand that the program does not do this, but it seems logical that a form may require this format and that it maybe the program should be able to do it.
Thanks again,
John
Post by Pablo » Tue Oct 03, 2017 6:03 am
jwallner
Post by jwallner » Wed Oct 04, 2017 12:46 am
:) I have something that works on a test page. I just need to rename a few things, but this function works and converts any decimal to a price in US dollars. baseprice and Editbox3 are number fields, and Editbox7 and baseprice_str are string values.
<script>
function myFunction() {
var formatter = new Intl.NumberFormat('en-US', {
style: 'currency',
currency: 'USD',
minimumFractionDigits: 2,
// Use it.
var amount = document.getElementById("Editbox3").value;
document.getElementById("Editbox7").value = formatter.format(amount);
var amount2 = document.getElementById("baseprice").value;
document.getElementById("baseprice_str").value = formatter.format(amount2);
</script>
