Is it possible blog style ( wordpress like) template ?
birxbir
Post by birxbir » Tue Sep 12, 2017 11:17 am
hi there
Is it possible blog style ( wordpress like) template ? if possible which tool should we use?
I would like to user add comments with php database for each article. Can it be done? Is it unnecessary?
thanks
Re: Is it possible blog style ( wordpress like) template ?
Post by BaconFries » Tue Sep 12, 2017 12:04 pm
Has been asked before by another member and yourself at the following and most likely the answer is the same Add-on to Generate WordPress Themes
Pablo's answer to thid
Pablo wrote:
Mon Apr 10, 2017 11:04 am
WordPress uses a dedicated format, it will be impossible to make all objects in the WWB toolbox compatible with WordPress.
Yes it can be done, the layout can be made with the programme but it would need a backend solution using PHP and a database. This is something you the Designer would need to implement yourself or source out or use a external script.
birxbir
Post by birxbir » Tue Sep 12, 2017 1:14 pm
ok thank you ,
as I know that topic was to the theme converter. I want to ask you if there is a template (paid)
Post by BaconFries » Tue Sep 12, 2017 1:23 pm
There is no Wor*Pre** themed templates as far as I know for the reasons mentioned by Pablo see his quote.
Forum member me.prosenjeet may have a Blog theme template you can view all his "Paid" templates are the following:
templates
birxbir
Post by birxbir » Tue Sep 12, 2017 2:38 pm
templates
Yes I found ,
http://lucknowwebs.com/author-blogger-t ... ilder-11x/
45$ or 20$
Thank you
Post by BaconFries » Tue Sep 12, 2017 2:50 pm
👍 If you decide to purchase and have any questions regarding this then please email me.prosenjeet through his site thanks.
birxbir
Post by birxbir » Thu Sep 14, 2017 6:18 pm
me.prosenjeet wrote:
Wed Sep 13, 2017 12:34 am
You may check this (paid):
http://lucknowwebs.com/author-blogger-t ... uilder-11x
I'm looking at it , but very expensive for me . Unfortunately, the dollar rate is high in our country.
I hope to find a solution.
thanks
