UDP command
planktone
UDP command
Post by planktone » Mon Aug 28, 2017 8:52 pm
is it possible to create an button that sends an UDP-command to an fixed IP adress ?
thx,
W.
Re: UDP command
Post by Pablo » Mon Aug 28, 2017 9:15 pm
There is no standard solution for this. This will require custom coding.
It looks like chrome support this:
https://developer.chrome.com/apps/sockets_udp
But it's not an official API.
planktone
Re: UDP command
Post by planktone » Tue Aug 29, 2017 7:41 am
thanks,
i try to understand ...
( i am not a great web-designer, to be honnest a dummy ... but i like very much the WYSIWYG approach )
maybe this does the trick ?
https://brightsign.zendesk.com/hc/en-us ... -interface
i have to send the UDP command "11*" to a fixed IP/port to activate a relay a relay for an art installation in a museum.
w.
Re: UDP command
Post by Pablo » Tue Aug 29, 2017 8:12 am
Yes, this may work.
Note however that I cannot give support on third party code. For me it may also take a lot of time to figure out how to use this code.
You can add custom code via the HTML tools:
http://wysiwygwebbuilder.com/add_html.html
planktone
Re: UDP command
Post by planktone » Tue Sep 12, 2017 9:51 am
anyone else ?
the idea is to control this relay board
http://www.ebay.com/itm/LAN-Ethernet-2- ... SwAKxWWBEm
with a (single) button on a website
thx,
w.
